Question about Steinberg Cubase SX3
How to connect a MIDI keyboard to computer
Keyboard: Roland PC 200 mk 2
Posted by john andersen on
batty 13
    New Friend:
  • 3 Answers
There are quite a few ways to do this.The simplest way is to just use the USB port on the keyboard and run that into the computer. If your keyboard has a USB, then you dont need the midi to connect to a computer. You would still use the midi however for other sound modules and items that do have a midi in port however. If you dont have a midi in then you need to get hardware that does as a computer will not have a midi in. There are basic adapters that you can get that just have a midi connector to usb adapter. There are external sound card devices that will do this like the tascam 144. There are also simple devices made my midiman such as the 2x2 midisport that allows you to connect up to 2 midi devices to a computer. The cheapest quickest method if you are just starting out is the midi to usb cable though. Places like walmart, best buy, and radio shack will generally have these. However with making digital music the cheapest is not generally ideal but will get you by in the meantime.If you ever plan on recording audio like vocals or guitar then I would recommend just getting something like the Tascam 144 MK II as it will allow you to input midi, spdif, vocals with phantom power, guitar line in, through it with 24/94 bit conversion, audio drivers, and a bit of software for simple settings configuration. This would be more of an intermediate interface. If you want some pro solutions, then I would recommend going to the pro's at a musician store and talking to them.
Posted on May 21, 2012
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Need user manual for MK-4902 midi keyboard
Use LMMS software on PC. You will need a MIDI to USB cable which you can get on eBay.
The manual can be found at:
webpages.charter.net/rochamalhada/MK-4902.pdf
Sep 20, 2012 | Music
How link my electronic keyboard MK 939 to compurer? what drivers are necesary?
I see the MK 939 has a midi out port. This can be connected to a midi in port on your computer via a usb to midi connector ( as shown in picture)davemello_1.jpg
Usb connectors have built in drivers so all you do is plug in, select the usb-midi device in music software.
A reasonably cheap one can be found here
http://www.amazon.com/Cable-Converter-Music-Keyboard-Window/dp/B0017H4EBG
OR
Connect keyboard via a soundcard eg soundblaster fatality with built in midi portsdavemello_0.jpg
Details of soundblaster products can be found here
http://en.store.creative.com/sound-blaster.aspx
A free version of music software is available for download here
http://www.multitrackstudio.com/download.php
Thanks for using fixya.
Jul 11, 2011 | Computers & Internet
When I connect my midi cables to my PC and use Fruity Loops or Mixcraft and I play notes on the Roland Juno D keyboard, some of the notes stick and dont stop playing once released and others are played...
You need to turn off the echo of the MIDI that sends the signals back to the Juno. When near simulataneous MIDI signals are mixed the decoder can receive "partial" messages that re-trigger the notes and then miss the note off commands. If you can't find the setting in the software, disconnect the input to the Juno MIDI while recording it.
Feb 05, 2011 | Roland Juno-D
How do I send Midi from my keyboard to my computer
BUY A MIDI LEAD,,,,,,,,,,,, FROM YOUR LABTOP TO YOUR KEYBOARD,,,,
Jun 18, 2010 | Acoustic Solutions AV 150B Main / Stereo...
Casio WK 200 keyboard, USB doesn't work
You may need to install the drivers to give the computer to fully recognize the keyboard. The computer may see the keyboard, but isn't recogning it fully due to the lack of drivers.
Dec 29, 2009 | Computers & Internet
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
I can not work with 3 sound midi modules, roland mks80, jv2080,ak
I assume roland mks80, roland jv2080,akai s 950 are all being used with a midi interface. You must make sure you download and install the latest driver softwarefor the midi interface. You do not need drivers for the instruments you mention but you must ensure your midi cables connecting the above devices are not damaged
Jan 19, 2009 | Computers & Internet
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
276 people viewed this question
Top Steinberg Computers & Internet Experts
Lawrence Oravetz
 Grubhead
Grubhead
Harrie
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
