Question about Samsung Freezers
What water connections does a samsung fridge freezer need?
I need to plumb in my fridge freezer. I wanted to run the copper pipe fairly close before it is delivered. I noticed in the store the pipe is a micro pipe with a screw on fitting on each end. One end will obviously go onto the Fridge Freezer and the other to a feed. What fitting do i need to put on the end of the copper pipe to screw the feed to. Is it like a washing machine fitting? Thanks!
marlin siecinski
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
They generally use 1/4" tubing.
Posted on Oct 23, 2017
2 Related Answers
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: hello!ad my black glass fridge freezer delivered
Post your model number for filter help. The water supply hook to the water inlet valve on the back, Usually near the bottom. It has a fitting where the incoming water will fit. You may have to remove part of the cardboard on the back to get to it.
Posted on Oct 28, 2009
Anonymous
  • 674 Answers
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Posted on Apr 04, 2010
Need to disconnect water line at back of frig to move it temporarily while floor is replaced. Connected with compression fitting and ferrule.
You may be forced to cut the copper pipe and buy a new compression fitting and ferrule and add it to the cut off end of the copper tubing when you decide to re-hookup the refrigerator.
Remember to cut the pipe , if you choose to do so, with a tubing cutter so as not to "smash" the cut end.
This problem can happen any time dissimilar metals are joined, they can "freeze" together.
God bless your efforts.
Apr 07, 2016 | Freezers
Converting 220v to 110v
No, I'm sorry, but this is not possible. But remember that 220 vac is just two legs of 120vac cycled 60 degrees apart. So 220 may be available there. Talk to the local electricians--you may only need a new plug and recepticle installed, or it may take extra wiring, depending on the buildings wiring and local codes.
Mar 27, 2014 | Freezers
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
My Maytag side by side with water dispenser and ice maker doesn't work. We bought a house - never lived in - and the fridge and freezer work fine. We replaced the water filter and find that no water comes...
The sadle valve is located on the copper pipe where the tube attaches to your water pipe in the house. Shut the water off at the saddle valve. Remove the hose from the rear of the frig on the water inlet valve and put it into a pail. Tunr the water on at the saddle valve and see how fast the water comes out. Some times if the saddle valve is installed on the bottom of the copper pipe they will get corrosive and restrict water flow. Open and close the valve several times to make sure it is clear and reinstall the hose to the rear of the frig. Turn the water back on to see if it works.
Dec 29, 2009 | Freezers
My 40 l does not wan to keep stuff cold teh motor kicks in only mometarily, can it be in need of a gas refill and does it ide normal aircon gas? It can get cold by itself but if you stick it with drinks...
If The motor is switching on for short periods, you either have a faulty compressor or a blockage. My money is on a blockage. Once cover is removed to allow you to see the compressor, look for a small fat copper tube that has a small 1/4 inch copper pipe on one side and a thin capillary tube connected on the other side DRIER). Flex this very thin pipe connected to the small fat tube(DRIER) untill it breaks.Gas will come out. Wait untill all gas is out then reswitch on and see if compressor still continues to switch off on short intervals. If it can run for at least 1 min without switching off, then get a Refr.Tech to come and replace drier and regas unit.
Sep 23, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Too much water coming out of the pan (in the front of the ice maker) and copper pipes on top left side are covered with ice.
Not real sure just what you are saying as to what pan? The copper pipes that go to the evap plates where the ice is made are supposed to frost over. They get colder than dew point of the air so this is normal. But all the pipes should frost. Does the unit shut down and give any type of beeping noises? This would be the control giving you a trouble code. You may have a water valve leaking. Turn unit off and see if water continues to run. All water should stop within a few seconds. Let me know what you find. Please verify model and serial numbers.
Aug 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Connecting to water supply
If you mean icemaker or water supply it's easy you just have to connect a water pipe 1/4 to your main water supply of your sink 1/2 inch. Just putting a valve first on the 1/2 pipe reducing to 1/4 & you bring it to your water valve solenoid of the fridge. That's it!
Francois
Dec 10, 2008 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
264 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
