I have Samsung SyncMaster™ 510N (Silver) 15 inch LCD Monitor dispaly picture for 3 to 5 second then there is no display but Powers led show proper
SOURCE: Samsung SyncMaster 510N
its time for u poeple to buy a new moniter .....or get it repaired by a prof tecnician.....the electrons which bambard on the picture tube at a point of time they become weak...n they loose there capacity......so the moniter starts dim and after wards when the moniter heats up it get fine !!!!!!!!!!!!!!!
SOURCE: syncmaster 920 nw lcd monitor dispaly problem
sounds like your having pixel issues I would advice calling up samsung and checking there pixel policy if it is out of range they will need to replace it
SOURCE: SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: We need your kind assistance for "repair LCD
Around here, it's impossible to buy a "new" 15-inch LCD monitor,
because "used" ones sell for about $30 US.
In comparison, a qualified TV/video technician will charge $60/hour to trouble-shoot.
So, rather than spending money to try to repair it, spend an equal amount of money, and buy a replacement monitor.
SOURCE: Samsung 15" Monitor 510N LCD
find LCD Power supply here: http://www.hismarket.com/lcd-ac-adapter.html
