Went into protect mode while being transported to my other house. Will not come out tried unhooking speakers and shutting it off.
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
SOURCE: onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
SOURCE: TX-DS838 shows protect and then shuts down
yes , Im afraid you have a chip gone , If you open the unit up you'll see a alloy heatsink with 4 to 8 large chips screwed to it , These are the amp drivers , In between these chips you see a smaller one (that is the protect chip),You see when things get a little hot this chip is designed to break sooner that the more expensive main amp chips , In the past ive unsoldered these and still found the amp driver bust too ,dont worry though , maplins or even farnell(cpc) on the web will supply these for less than a tenner..If you wanna test my fix then just unsolder the littlest chip on the main heatsink and it should start to work again but with NO protection(unplug it first before taking it to bits)
