First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
SOURCE: My Gateway MX8711 Notebook PC won't boot up. It
it might have to do with your hard drive... try taking it out and putting it back in.
SOURCE: my GATEWAY COMPUTER WON'T
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
SOURCE: i have a gateway mp8708
One of two things are likely your problem:
1) The battery is so dead that it's preventing any power from reaching the rest of the PC. Try pulling the battery out, plugging the laptop in, and turning it on.
If that doesn't work,
2) The motherboard power converter is burned out. If this is the case, unfortunately you will need a replacement motherboard or a replacement laptop.
Good luck, and hope this is helpful!
SOURCE: I have hP mini 1000 that won't boot up
you will need a copy of windows and an external disk drive then have it boot from the cd when it boots select install windows then leave the current drive intact with no changes or if the repair option comes up you can select that. do not select the repair at the first menu unless you are an expert in dos, always go to the install.
SOURCE: Got a laptop from a
