Question about HP Pavilion DV9727CL Notebook
I need a cd/dvd driver - HP Pavilion DV9727CL Notebook
Posted by Darryl on
Chris Hingee
  • HP Master
  • 32,281 Answers
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Posted on May 21, 2012
Hi! I need driver for GH22NP21 model please
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Jun 01, 2011 | LG GH22NP21 DVD-Writer - Internal...
The dvd/cd station does not work correct, every time he put out the dvd or cd
Try re-seating the DVD/CD drive and then Check Device Manager and check DVD/CD driver and if it has a yellow ? against this drive then the DVD/CD driver needs to be re-installed.
If this item is OK then the DVD/CD drive may be faulty and needs to be replaced.
Apr 23, 2011 | Acer Aspire 5735 Notebook
Need the correct drivers
Dvd/Cd Rom/Writers don't need a specific driver, their necessary drivers come with all the operating systems available. The only thing you can do is, update the windows or repair the Windows.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 | Samsung SH-S223B/RSBF DVDRW Drive - DVD+R...
I accidentally uninstalled the DVD and CD drivers and camera driv
look for the drivers at google.com. download the drivers. make the that you have the right product # of the dvd drive and camera. and install them again. but if u have windows 7 OS, all you need to do is restart your computer.
Mar 29, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Acer dvd driver missing acer ferrari 400 dvd uj-845-c
CD/DVD drive drivers are Operating System generic drivers and need not to be installed explicitly. The CD/DVD drive drivers are installed along with the Operating System and can be reinstalled automatically at next restart, if missing.
Check in the Device Manager under the "CD/DVD drive" category if there is any device listed there and having exclamation mark. If there is any exclamation mark visible beside the CD/DVD drive name then right click on it and restart the Computer.
Restarting the Computer will reinstall the CD/DVD drive driver thus causing it to work normally.
Nov 25, 2009 | Acer Ferrari 4005WLMi Notebook
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
Cd rom recognised as cd audio
They will definately need drivers to be able to give out 100% of the performance.
You definately might have receive a disk while purchased the CD/DVD ROM.
Try that driver once and see the difference.
Jun 03, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Dvd drive of my hp dv2000 is not working. it does not read dvd or a CD, and message pops up insert a CD or DVD. drivers are updated. in its hardware config. it says drive cannot be started. do need to...
There is a screw (tiny machine screw) that holds the entire DVD/CD assembly in place. Usually this screw is located by looking on the bottom of the laptop and has a little picture of a cd embossed in the plastic. Sometimes this screw is under a "lid" such as the cover for the RAM or HDD, depending on how your laptop is engineereed.
Find this screw, unscrew it, set it aside and them pull entire cd/dvd assembly from computer. Replace the cd/dvd drive into the slot you pulled it out firmly and quickly.
Turn on and test reading of CD/DVD.
If love is found, replace screw holding asembly, etc.
If no love, replace CD/DVD drive.
Other sources of love:
correct cd/dvd driver.
remove/replace cd/dvd driver
update cd/dvd driver
Mar 04, 2009 | HP LightScribe dvd640i (DVD640I)...
Need toshiba dvd/cd drivers for laptop
hey,
the drivers come with windows, you shouldn't need a driver.
If you look into device manager and the drive has a error code about driver, for example code 39
have a look here
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Jan 19, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Driver
I HAD MISSED MY SONY CRX 320EE DRIVER CD. NOW I AM UNABLE TO PLAY DVD IN MY SYSTEM PLEASE SENT DVD DRIVERS TO SUPPORT MY DVD PLAYER IT HAD ASKED COMPATIBLE DVD DECODER IS NOT AVAILABLE.
Apr 03, 2008 | Computers & Internet
HP Pavilion DV9727CL Notebook Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
