SOURCE: 8 hp briggs no spark,new coil ,new electronic
make sure the plug wireisn't grounding on sheet metal. Verify current to ignition module and that module is securely mounted for grounding. Negative side of coil to module, pos to ignition switch or starter button . Chk for current at coil +. . Coil -- should pulsate when cranking. Ensure there are no inline fuses, fuse box fuses, or fusible links incorporated into wires lesding to module. Good Luck_Ned_
SOURCE: trying to change the points on an old briggs and
Need to know what model Older engines have points "under" the flywheel. Use a wheel puller to remove after removing the nut in the center of the flywheel. Newer motors have an electronic ignition module. Follow the small wire from the magnetio. If it goes under the flywheel then you have points. If it goes to a small device on side of motor, you have electronic. You can go to http://www.briggsandstratton.com/ and look up your odel number.
