Question about Dell Computers & Internet
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
Posted by elagebru2003 on
Chris Hingee
  • Dell Master
  • 32,281 Answers
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on May 21, 2012
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: dell inspiron 6000 not charging
I have a Dell Inspiron 6000, and so does my wife. One day coming back from the airport, the power adapter cord(the end that plugs into the laptop) was hanging out the door and was dragging on the ground. Well the end was unusable and I was out looking for another AC adapter. Dell wanted $80 for a new one, but I found one on ebay for $40. But once I got it, I found that it would power my laptop, but wouldn't charge my battery. I thought, I know the old one works, so I cut the end off the ebay one and wired it onto the original one but ended up with the same result. Called the ebay seller and turns out these AC adapters are dell seconds. They claimed to test them and offered to send me another one and did so. By that time the new one from dell dropped to about $40 so I just bought it too anyways. The new dell one worked and the second one from the ebay seller did the same as the first one he sent me. I found out that the dell laptop wont charge the battery if the supply goes below 19.5V. By me hacking the other end on the original AC adapter, didn't result in the best insulated connection from the other wires. Also, if anyone know anything about AC adapters, is that they have a "Step Down Transformer," and the company that makes them, low balls the windings so that if they are off on the voltage, they are under, and not over, thus not frying the more expensive laptop. My suggestion to you is to just pick up a new AC adapter from dell. Also, the rubber coating on the cord is pretty soft and splits easily.
Posted on Dec 31, 2008
Anonymous
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
ABRsvcs
  • 4234 Answers
SOURCE: wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
Posted on May 05, 2009
Anonymous
  • 62 Answers
SOURCE: dell inspiron 1525 will not charge the battery
This problem has arised because your motherboard hasn't identified your battery. So, this is motherboard problem.
next time when you chat with the dell representatives, tell them that your motherboard is not recognizing your battery. They would arrange a pickup and would have it repaired in their center.
Good luck,
~regards,
Jegan
Posted on Jun 03, 2009
Anonymous
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
Baterry isnt charging it only works on AC power DELL PP22L
Press the function and F3 button. This will enable/disable charging. If that does not work, then you either have a power adapter that is not creating enough voltage to charge the battery or the battery has gone bad.
Oct 21, 2012 | Dell PP22L-XT279 Core 2 Duo 1.6g 1gb Ram...
Dell inspiron 1545 not charging battery how do I check Motherboard?
If the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes
Please let me know if it's working
Jul 26, 2012 | Dell Inspiron 15 1545 Notebook
AC Adapter not charging
It is possible AVG has disrupted the settings, I would be tempted to run a system restore bringing the computer back before you installed the software, if this works! do not install AVG.
Apr 15, 2012 | Dell Inspiron 15 Laptop
Dell inspiron 15 pp41l will not power on
Remove battery and clean contact points and reinstall the battery! if still does not work charge battery full and try again! If still does not work either battery is defective or power cord may not be good to charge the power!
Sep 23, 2011 | Dell Inspiron 1501 Notebook
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
I have DELL LATITUDE D810 I am having an issue charging it`s battery, when the AC Power adapter is connected the notebook works fine, but the battery does not charge, as soon as I disconnect the power cord...
Yo! i think you should try something.get a friend that uses your type of adapter, try charge it with that and see if it responds.if it doesn't charge, you will have to replace your battery which means its spoilt.
Jul 24, 2011 | Dell Latitude D810 PC Notebook
I replace my ac power supply for my dell laptop inspiron 9100 but when connect the power supply to the laptop it keeps on blinking and the laptop does not power on
If you can , try charging the battery in another system and then try to power the laptop up with the charged battery.
If the unit will run on a charged battery, then there's a problem in the charging circuit, and you'll have to check all the components in that area.
If it doesn't, then there's a problem elsewhere on the motherboard, possibly in the DC/DC converter circuit.
Check for shorted SMT MOSFETs and blown or failing capacitors.
If you aren't tech savvy, this is not an undertaking for the inexperienced, and you may have to have the unit sent out for repair.
Most places don't do component level repair and will simply tell you that you need a new motherboard.
If you cannot find a service depot near you, you may want to consider going to www.supertech-IT.com and arrange to have the unit sent in.
Jul 20, 2011 | Dell POWER SUPPLY Power Supply
Dell 1737 - Battery plugged in not charging. No one has a solution, only suggestions. New battery, new charger. I don't believe this is a motherboard issue. I believe this is a problem with the OS,...
Hi swd6,
Just to isolate the issue, could you kindly remove the battery from your laptop and using the AC adapter alone charge the machine. Please let me know if it's charging.
Thank you for using FixYa.
Jun 16, 2011 | Dell Studio 1737 Laptop
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Open Questions:
Computers & Internet Logo
334 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
