Speakers won't turn off. Music plays loud even with head hones in.
SOURCE: Outside speakers won't turn off when I put my headset in.
There is a switch inside the iPod Nano headset female jack that is deactivated by headset the male jack when it is plugged in. The switch deactivates the outside speakers. In your case, the switch is not deactivated so you hear sound from both. Three things may cause the problem that you need to check.
SOURCE: nano won't play music just through my headphones-
1 Please check the headphones on any other device to make sure that there is nothing wrong with them and they are functioning normally. 2 Switch on the Nano and press MENU 3 Go to settings and go to clicker. It will show 'speakers' 4 Press the center and it will change to headphones. 5 Set it there. 6 Similarly you can adjust the volume.
SOURCE: the mp3 player is an element gc-823. I just finis...
Mine is doing the same thing exect that if you unplug the head phones from mine you can hear music how do I shut the external speakers and listen to it with head phones? [email protected]
did you find a solution
