Come collegare videocamera vp d351 al notebook
SOURCE: model number vp-d351
i had same problem, solved it with replacing the lcd fpc lead (ribbon).this is the lead to the screen.it breaks after about three years.this is a common fault.. replacement part from Partmaster.co.uk or 0870 240 6603..part number..SAMAD9706489A. cost £11.40.. its easy to replace ..takes a little time.. i have emailed instructions to two others and they have sucessfully completer the task.. if i can help with instructions,please ask.. i have also purchaced a second ribbon for next time..(3 years time )..good luck stefan.
SOURCE: VP-D351 need to connect with TV. What type of cable is required
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
SOURCE: I have a Problem with my Samsung VP-D351 Pal. When
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=VPD351&searchInputBox=VP-D351&find_button=
when vp-d351 is input, I get two downloads one for software and one for a driver.
I could not locate the instruction manual.
You could contact Samsung to talk to them about this problem:
http://www.samsung.com/us/info/contactus.html
