G-2 928D model-while mowing it gets hot-I let it idle till it hits the green on the graph wait 30 min to go back and mow and it gets hot in 10 min again. Cleaned radiator and screen protector but to no avail continues to over heat.
I have looked through a lot of
Post about the same mower n grasshopper diesels altogether and didn't find an answer . I went to the repair shop in the months to follow the overheating and I figured the problem out after seeing the engine cover missing of off the majority of grasshoppers . The cover holds the heat in . Our mower no longer gets out of the green . I m sure u will figure it out after u testy theory
SOURCE: engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
SOURCE: Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
SOURCE: bolens st160 hydro eliminator 16hp
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
SOURCE: MY ******* WILL SHUT DOWN
You have a Ignition Coil (Module) going bad. This is how they act right before they quit completely. You may be able to pick one up used pretty cheap from a small engine shop.
Good Luck!
Jim
SOURCE: When mowing engine dies, have
Check the oil it might be low and the tractor might have low oil swith.
