Hi, I have a kohler confident 5 generator in my motorhome that won`t start, its has not been run for two years, it will start to run with a prime to the air cleaner and when the prime is used up it will stop.
SOURCE: My Kohler Confidant IV generator starts and runs
Kohler generators feed the generated voltage back into the control circuit board to tell it to keep the fuel pump (electric) runing and the ignition on. IF there is no voltage generated (bad brushes or?) then the symptom you describe will occur. The motor runs fine, but it isn't generating electricity.
Jim Russell
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
SOURCE: Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Testimonial: "Thanks. Will take your advise to my electronic wiz-kid friend who has the generator regulator, & is going to run tests. Will let you know the outcome."
