Not sure if this will help or not===it is for a Dynex DX 55 and is the owner manual free link=copy or download.
http://www.manualowl.com/m/Dynex/DX-55L150A11/Manual/198176
SOURCE: I can't get the closed
Check the remote have a button CC.Used the CC button turn off all CC1,2,3 all off.Or goto tv Menu find closed caption 1,2,3 or Text 1,2,3 turn it all off.Will not get anymore closed captioning or big black boxes anymore.
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
SOURCE: Unable to remove the closed caption through the
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
SOURCE: The closed caption will not turn off on my Dynex
that a tipicle Dynex problem the main eprom is corupt you will need a new maonboard single parts not sold seperately
SOURCE: need owners manual for dynex dx-l19-10a
You can download the owner's manual by clicking this link.
Thanks for using FixYa.
