Looking to gange the fuel filter
The fuel filter is mounted on top of the fuel tank by 1 10 mm bolt. Remove this bolt (Spray some WD-40 on it first, so it won't break on removal). Then, squeeze together the plastic tabs at the ends of the fuel lines and pull the line(s) off. REMEMBER, THE FUEL IS UNDER HIGH PRESSURE AND WILL SPRAY WHEN YOU REMOVE THE LINES!!! KEEP ALL DROP LIGHTS AWAY FROM UNDER THE VEHICLE!!! You'll loose a couple cups full of fuel, be prepared!!. Also, when installing the new filter, put some motor oil on the lines prior to sliding the new fuel lines into place. This will prevent damage to the O-ring(s) in the new filter lines. Make sure the plastic tabs "snap" into place, try pulling on the filter line to make sure the clip(s) are engaged. And as Curious stated, you'll need to know the wheelbase of your van to get the proper filter.
I had the same problem with my old 1987 Chevy blazer s10. The problem was the ground wire of the fuel tank was rusty and it broke. So simple was the problem. But before that, I checked and change the fuses, the fuel filter, the oil pressure switch (this is related to the fuel pump to) and finely when a was ganging the fuel pump saw that the ground wire was broken or damage.
I hope this can help you.
