Question about Xerox Phaser 7400/N Printer
Xerox Phaser 7400 U28 error message
Cyan Imaging Unit defective
    Scholar:
    New Friend:
  • 77 Answers
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
Posted on May 20, 2012
2 Suggested Answers
SOURCE: Cyan Imaging Unit Failure, U28 Error Code
I just got that error couple of weeks ago on my 7300. I did everything you did and nothing so I ended up visiting www.iteminconline.com. I called them up and they told me to check all the cables on the engine control board 116-1538-00. I made sure the white data cables where connected and still nothing so they recommended me to buy a engine control board. That did the trick. Hopefully this will help you.
Posted on Oct 06, 2009
StevenC82
Steven C
  • 160 Answers
SOURCE: xerox phaser 7400 giving error
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Posted on Aug 11, 2011
I have blue lines appearing down one edge of the paper printouts
This is caused by either a problem with the Transfer Belt Unit or the Cyan Imaging Unit. Since the lines are only in Blue (Cyan) I would more suspect the Cyan Imaging Unit. These can be released and slid out of the machine very easily and you could look at the drum to see if the lines are there. When you slide out the unit the drum (long greenish colored cylinder) is right there on top and it should be clean with no toner lines on it. If there are lines then that would be your proof. Also try using your cleaning tools on the Imaging Units as well. This is the wand that is clipped inside the front door. There are also little blue knobs on the units you can pull out and push in a few times to clean wires inside the units. This will sometimes fix the lines. If not you may have to have the Cyan I/U changed.
Good Luck and Thank You for usng Fixya.
WheatlandServices
Nov 04, 2010 | Konica Minolta bizhub C250 All-In-One...
I am getting a very light cyan patch on my print area on canon iR C3200 printer
Most likely coming form your cyan imaging unit. I would open the front cover and slide the cyan unit out and ensure that there is no extra cyan developer on the top of the unit. As well, manually rotate the roller in the direction that it normally spins and inspect for any horizontal or vertical banding. If you spot any bands of color, try to manually clean them off with a soft rag or cloth (do not use any solvents.) If after reinstalling, the bands reappear, then you will need to replace the cyan imaging unit as the developer has gone bad.
-David.
Nov 02, 2010 | Canon imageRUNNER C3200 Copier
C-2551
Hi, C-2551 on the bizhub C250 means the sensor that measures the Cyan toner level has detected it as low.
It's likely to be the Cyan Imaging Unit has failed. But you can do a couple of things first though.
Remove the Cyan toner, give it a shake and refit.
Remove the Cyan Imaging Unit, give it a gentle tilt (45 degrees or so). Tilt it backwards and forwards a few times, then refit.
Hopefully the code will be gone.
If not, it sounds like the Cyan Imaging Unit is faulty.
Regards
Tam
Apr 19, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
C- 2551
Regards
Tam
Malfunction c-2552 konica Minolta c252p
Hi, C-2552 on the bizhub C250 means the sensor that measures the Cyan toner level has detected it as abnormally high.
It's likely to be the Cyan Imaging Unit has failed. But try this first..
Regards
Tam
Apr 15, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
May 22, 2009 | Konica Minolta bizhub C250 All-In-One...
the only thing I can suggest is to check the contacts that the imaging unit goes into, and i can also be the imaging unit itself. If i am not mistaken, you should be able to swap imaging units from another color just to see if the error goes away. But if this does not help, you will need to get it serviced. we have fixed these before, and its not a quick fix.
Apr 21, 2009 | Xerox Phaser 7300DN Laser Printer
Im running 12"X18" sheets from the manual feed tray..
You should print the "Repeating Defects Page" Using the printer's front panel menu keys perform the following steps:
  1. With Information highlighted, press the OK button.
  2. Scroll to Troubleshooting by pressing the Scroll Up or Scroll Down button.
  3. Press the OK button.
  4. Scroll to Print Quality Probelms by pressing the Scroll Up or Scroll Down button.
  5. Press the OK button.
  6. Scroll to Repeating Defects Page by pressing the Scroll Up or Scroll Down button.
  7. Press the OK button to print the Repeating Defects Page.
Most likely you have a defect on your magenta imaging unit. Switch the Magenta and Cyan imaging units and try the test print....if you have blue spots 3 3/4 then it is the imaging unit (drum). If not you may need to change the belt cleaner assy.
If it isn't the imaging unit then it will be a problem with the fuser rollers, so replace the fusing assembly.
Jan 15, 2009 | Xerox Phaser 7750DN Laser Printer
Too much yellow disbursing
Sounds like the yellow imaging unit it defective to be honest. I know its new, but may be bad out of the box.
May 20, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7400/N Printer Logo
253 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
