The water line going to the water valve assembly was cracked 2inches above the valve. I removed the valve assembly thinking I could just cut the line clean and reinstall, but I pulled the 2inche piece out with a pliers rather than removing the c clamp and pushing down on the skirt and pulling the broken piece out the correct way. So I broke the assembly and need to buy a new one. Once I receive it how do I install the old line into the unit? Do I remove the c clip push down on the skirt and push the line in, then install the c clip back between the skirt and the assembly?
SOURCE: Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
SOURCE: removal of broken funnel assembly and installation of new one
You will need to remove the front display panel to get into the funnel frame. Look at the bottom of the frame and you will see a little slot to slide a screwdriver in. With your screwdriver, insert it into the hole and pry gently. You will hear snaps and cracks as it comes apart. It may sound like the plastic is breaking but that is normal. Once you remove the display panel, you will see the frame and just replace it with the new one.
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
SOURCE: connect water line do i have to open the back cover
if you reamove the back you should see a preassembled water line stuck back there
slide it out ansd into the cannel
SOURCE: how to replace the filter
Take the new water filter out of the box and remove the two red shipping caps on the end of the filter.
The water filter is located on the front panel down near the floor.
Push the release button located just to the left of the water filter grille cap, this will release the filter.
Remove the grille cap from the filter by twisting it counterclockwise.
Reinstall the grille cap on the new water filter.
Insert the new water filter in the refrigerator making sure the words on the filter are the correct side up.
Push the water filter in until it clicks in place.
Flush Water After Installing New Filter
Be sure you flush out the water from the new filter after you replace it! Many readers are having trouble with airlocks because they are skipping this important step. Kenmore recommends you run the water out of the water and ice maker for a few minutes to flush out the new filter. This also helps remove air bubbles from the system. If you don’t do this it’s possible that the water dispenser may not work properly due to an air lock.
This particular water filter claims to reduce:
Cysts and turbidity – linked to gastrointestinal problems
Lead
Chlorine – taste and odor for better tasting water
Sediment – for clearer water
o-Dichlorobenzene – linked to risk of liver, kidney, or circulatory system problems
Benzene – linked to increase risk of cancer and anemia.
Note continue changing the filter on a regular basis.
Hope this helpout....
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
