I have never used the panic alarm, and won't use it again. It was only activated for under 60 seconds, so I don't think the battery is dead.
SOURCE: HOnda Accord EX 1998 ALARM
Have you tried putting your Valet (original keys) into the ignition and turning it to the II position?
SOURCE: 2003 Honda Odyssey Passenger Sliding Door Lock
I had problem with the door not opening from the inside because my kids put the child latch on.
SOURCE: 2004 Honda Accord: Key will not disable alarm (not a key problem)
try pulling your negative terminal lose from the battery for a few minutes and allow the system to zero out then try it if tht don't work then visit your local honda dealership
SOURCE: Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
SOURCE: 2005 Honda Odyssey Tailgate Problem
Try to reset the tailgate by removing the no.7 (7.5 amp) fuse in the underdash fuse box. Open and close the tailgate manually, reinstall the fuse, and try the open tailgate button. If that doesn't work you would have take it to the dealer, where they can check for DTC's (diagnostic trouble codes). Honda Al
