HP Pavilion dv7-1245dx Notebook Logo
orville Posted on May 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plugged in not charging, 1245dx will not run on only ac power
Tried batteries, chargers, updates, tricks and tips, it just keeps happening over and over search and search for answers hp got in bed with the devil and I'll never buy another hp product in my life
John A. Crowder
Level 3:
  • Master 470 Answers
  • Posted on May 20, 2012
 John A. Crowder
Master
Level 3:
Answers
470
Questions
0
Helped
109683
Points
1411
That is just it HP is proprietary, meaning you may have to purchase their battery and their stuff in order to resolve this no third parts things outside of HP will work. Has to be exact for your model I never loved HP myself. I have had a few of them and they are piled high in my repair department. So last resort get their batteries make sure it is from them period. BIOS has to also read this battery in order for it to function when charging. That is all I have to offer on that matter. John
5 Related Answers
A
Anonymous
  • Posted on Aug 11, 2008
SOURCE: Compaq laptop problem
Hi WV,
I am still testing on the battery and so far no problems with the flash drive in. The slow booting is due I think to Avast updating the virus database at the same time. Otherwise it boots OK. I am getting an error at shutdown "SynTPLpr failed to initialize properly" I have also noticed that I don't need to click on the user login at boot time, only place the cursor over the name and it takes off by itself.
pontelemon
pontelemon
  • 538 Answers
  • Posted on Apr 16, 2009
SOURCE: laptop wont boot and the battery and power lights flash
"......no beeps and it is a 3rd party charger for this model of laptop."
That 3rd party adapter could be the problem. Also, try to take out the battery and power it up from AC adapter only.
Ideally, try to find original AC adapter just for testing.
Anonymous
  • 10406 Answers
  • Posted on Apr 27, 2009
SOURCE: HP6720s run slow when plugged in??
Start -> Control Panel -> Power Options
Ensure that when plugged-in, it is set to "Maximum Performance".
Anonymous
  • 8 Answers
  • Posted on Apr 28, 2009
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Anonymous
  • 360 Answers
  • Posted on Feb 27, 2010
SOURCE: HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Testimonial: "Very helpful but problem remains"
2answers
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Battery not charging
does the PC run good , battery out, and only on AC, it must.
does it?
  1. bad battery
  2. bad power pack 19vdc 65w
  3. or bad charger chip in the PC.
did you give it 24 hours to charge.
1helpful
My battery do not keep any charge, but its condition was diagnosticated as "excellent" with specialized programs. The laptop works only with an automatic multi adaptor (Woxter brand). The system reports...
"plugged in, not charging" could a symptom of incompatibility between the charger and the battery.
If this is the case, once you unplug your ASUS ac adapter, the laptop goes off.
Anyway, it's still Ok to use the charger but you need to plug it in all the time.
Here is a little trick that I found that works.
1. Power up the Notebook with the battery installed,if you can.
2. Turn the computer completely off and remove the battery.
3. Power up the Notebook with AC power only (no battery installed).
4. Turn the computer completely off and re-install the battery.
5. Power up the Notebook.
6. The message no longer appears (at least for me it has disappeared).
1helpful
HPG62 A45SA keeps cutting out while plugged into the mains (the battery has been removed). With the battery this problem doesn't happen. Instead, the plugged in not charging sign...
Sounds like your cable/charger/ computer AC plug in had been pulled, damaged, or the transformer is going out. If you can lat you hands on a similar known good AC cord it would help you trouble shoot the problem, you could eliminate the cord and focus on the computer plug-in. The AC/Charger cord transforms AC to DC to charge you battery and and run you computer. Another cable has to have similar specs (output voltage) as to not damage the components. As to the " plugged in not charging sign appears...", Is the battery old, replacement, does it deplete after using?
2answers
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
2helpful
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
2answers
Dell laptop will not accapt ac power or charge
hi
please update the latest version of BIOS
if that does not work please contact the dell technical support they will replace the ac adaptor or
33helpful
5answers
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
