SOURCE: PROBLEM WITH KEYBOARD
dear,
first try with reinstalling the driver.. but uninstall the previous one completely..
if still facing the problem then it could be ur window problem.. a virus or something else..
by the way, is it work fine on notepad, ms word or word pad.. if yes, then the max. chances is that, it could be the windows problem
regards,
hope it will help
SOURCE: Keyboard beeps when any key is pressed
The reason these beeps are happening is because there might be a key that is slightly depressed enough to where its registering keystrokes. Move your fingers all over the keyboard and see if you the beeps stop after you do that. If it still is going on then that means your keyboard is bad and will need to be replaced.
SOURCE: Some of my keyboard keys on my new vaio are
hit the num lock key :-) look on the j k and l keys and i bet they also have a 1 2 and 3 on them.same with uiop 456*
Testimonial: "Thanks, that was exactly it. I've never had a laptop where the numberlock key did that before. Good to know!"
SOURCE: my logitech wireless keyboard won't type. i
u r keyboard is likely to b defective or ur ram..
lightly strike/tap the keypad using ur hand..
if
u r a professional, open the keyboard..deep clean all the carbon
contacts beneath the keys using Iso-Propyl alcohol..put/stick
'Carbon-Dots' (available in cheap level spare market) as n where
necessary..
hope it'll work..
else better to seek professional supervision esp of ur system admin/vendor....
SOURCE: is there an on/off switch on Logitech wireless
No but, you might want to uninstall and reinstall the software that came with the keyboard. Your computer might be confused about which keyboard you are using.
if its a wireless mouse and keyboard make sure the batteries are securely seated and fully charged the battery panel should be on the underside of your mouse keyboard as would be the on off switch
click start control panel keyboard hardware make sure the right type of keyboard is selected
click start control panel keyboard hardware troubleshoot or click start control panel administration tools computer management device manager scroll to keyboard you could see a yellow question/exclamation mark ? ! or red X a new driver will need to be installed
right click to install drivers
http://download.cnet.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
hope this helps
