After I sign in about 23 error messages pop up then a wIndow comes up that says S.M.A.R.T scan and starts scanning and telling me i have bad files
That particular virus infection is a SERIOUS pain in the ****. Save yourself a major headache and bring it to a computer shop that specializes in virus/malware removal for a set price of $50 - $100. I've personally removed that virus from several computers and it's very tricky, and great at morphing and hiding code in several places. Not to mention the fact that it will eventually delete all your icons on the desktop and start menu.
SOURCE: Insufficient Memory
Consider this. Your dell came with 512Mb of memory. The dell video card is integrated which means it uses your system memory to function. There are three choices that I can recommend. 1st. Enter your bios & reduce the amount of memory going to your video card. 2nd. You can add a PCI video card which would give you back your system memory. Lastly.
Which is the better choice. Buy another 512Mb Dimm of memory & add it to your PC. This will bring you up to the max memory your Dell can take, 1BG. You can check these two links & pick between them if you choose.
Link One: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=427379&body=MAIN#detailspecs
Or
http://stores.channeladvisor.com/Arch-Memory-Electronics/items/item.aspx?itemid=1884786
Either memory should run just fine & you do not have to try returning McAfee.
Just in case I'm including a link to a PCI video card list.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1603&Nav=|c:319|&Sort=0&Recs=10
Hope this helps you decide! Luck.
please vote..
SOURCE: virus found but not copied / quarantined
Do the following
Go here
http://www.malwarebytes.org/mbam.php
Download free version & run a full scan (it will update first). Remove any problems it finds (may request restart.)
Then go here
http://housecall.trendmicro.com/uk/
and run a free online scan. Again agree to remove anything found (may request restart.).
The time that this could take has to be worth it so be patient.
Neither of these are to be treated as replacements for your AV prog you have in place, I do however recommend you run Malwarebytes on a regular basis. The free version needs manual update every time before you run a scan but it is fast to load and fast to run, housecall on the other hand run less often and the speed of it depends on your internet connection. Two very usefull add-ons though.
If you still have problems then download this
http://download.cnet.com/Trend-Micro-HijackThis/3000-8022_4-10227353.html
Run, save log file and email to me on [email protected] from that I will be able to see if there is any other Malware or spyware affecting your system and advise on removal.
Anyone else reading this post is well advised to do the same as a matter of course. The security of your PC is only as good as the amount of times you run/update you AV prog.
SOURCE: DELL DIMENSION REFORMAT WITH DISC
probably ur ram is faulty..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
..contact ur system admin/vendor
SOURCE: can't scan to file with canon ir c2880
unistall and reintall Cannon irc2880. go to Cannon site to get the drver and software.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
