Toshiba 57h83 57-inch Hdtv-ready Theaterwide Projection Tv Logo
Question about Toshiba 57h83 57-inch Hdtv-ready Theaterwide Projection Tv
How to hook at&t uverse cable box
The cable guy thought the tv was broken, but i have perfect picture for movies and games. i need advice on hooking the cable box up so that i can have picture on the tv. if it will require an adapter of some kind, or work at all. thanks for any advice
SD Tech
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
Posted on May 20, 2012
5 Related Answers
Anonymous
SOURCE: sound is out for all inputs on Toshiba 51HX83
There is a switch on the back of the TV for center input. Make sure you have this set to OFF.
Posted on Dec 28, 2008
tlm931
T.l. Moore
  • 273 Answers
SOURCE: My Toshiba 55" TheaterviewHD works
it sounds like a convergence problem and there are different settings for 720 and 1080 in the service registers
Posted on Jan 16, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I just hooked up a HD cable box. However, cannot
This is a early HD set---what I call first generation--IT DOES NOT HAVE THE 16 X 9 FORMAT.
Many of the early HD sets are like this--4 x 3 or letter box type HD picture only.
Sorry to give you bad news but based on the model number it does not have 16 X 9 format.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 10, 2009
Testimonial: "thanks."
Anonymous
  • 1030 Answers
SOURCE: basic cable scrambled on ANT input but not PIP
it sounds like you have the common problem with these models. The poblem has occured so offten that toshiba issued a service bulliteen about it. There is a problem with a cuircit board called the Hypermodule its a signal processing board/ the ideal situation would be replaced this board but it has happen so much it may be difficult to find this ooard so this board can be repaird. The secound problem is to fix this board 11 very very small parts called capacitors need to be replaced. i have also replace these and only someone advance in solder should attempt it very small. twezers and magnifer. You can hire someone but it very labor intensive. Our shop charges 300 just in labor It can be fixed but I would adviise its just no worth it
Anonymous
  • 178 Answers
SOURCE: picture scrambled
unsolder a box behind the input board, (take it out or place it in carefully, do not force). Replace 11(10u/16v) capacitors, as you see on the picture.2267865.jpg
Posted on May 16, 2010
2answers
Last night my tv worked just fine this morning I go turn the tv on and there's no sound but there is a picture on my 50" Hisense flat screen tv
Check all sources , ie cable box, dvd player or video game. If all have no sound check mute setting in menu or on remote. iI just cable box or sat receiver or evan att uverse box turn them of then back on. the uverse box you may have to remove power. If still no audio request service. The problem is likely the main board or speakers .
Tv won't read the cable when hooked to the cable wire without cable box
Hello, Mary -
Your cable TV provider probably requires all TVs accessing the cable service to have their own cable converter boxes.
Note: An extra cable converter box will probably cost an additional monthly fee.
We have AT&T Uverse as our cable TV provider and need a cable converter for each TV.
1helpful
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
3answers
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
3answers
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Yamaha RX-V363 input settings
HI,you are not getting picture because the yam 363 dose not upscale or convert the picture from the composite input to hdmi.You will have to put a video cable from the composite out put on the amp to a scart convertor into the tv or put console picture into the tv and sound to the amp.
hope this helps.
CABLE GUY.
Open Questions:
0answers
Whirlpool Side by Side American style Fridge Freezer too hot and too cold! I have model S20D FSS10-A/D Service number 8586 161 15000 Side By side FF - and after replacing many components on the rear board 13 years ago it has been running well. However.... with a new fault I am hoping that the symptoms may allow someone to point me in the right direction. Not having a circuit diagram has been a hindrance. Over last few years the front panel inside in the fridge in my model has been developing a display fault - it started with the LED display winking out briefly about twice a second. The mark/space of time for the 'winking out' changed slowly to 50% on 50% off twice a second to eventually become just flashing on briefly twice a second and finally off all the time. However, the default settings/functioning of the FF has been working fine so didn't need to use the panel. However, can't read any fault codes that might be there I don't think that the buttons are doing anything on the panel. It has 15v supply but I don't know what supply voltage from the rear PCB should be. Then... A few weeks ago the house RCD tripped once and the fridge bulb had blown ********* stain on bulb interior and Relay RL3 was chattering randomly - I took the board out and noticed a fried circuit track where it looped thinly either side of component hole that was unused. I soldered in a bridge over the gap. Restarted the FF. From then the freezer cools to -32c and warms up to -2c and down to -32 etc.. The fridge varies in temp but does go as low as 0c and high as +9c. Alongside this, when the compressor is not running we can heard a ticking noise and identified that the compressor fan was turning slowly about ?100 rpm There's no ice build up, the freezer to fridge air louvres are opening and closing when you switch the FF on, and do seem to open and close at different times. The evapourator fan seems fine as does the compressor fan, the bottom of the fridge is dust free and the rear panels are all on to allow proper cooling of the condensor motor. I pulled the board again, checked all the capacitors I have a slightly different board to many and all the capacitors I had used from one brand have failed again. I took all the caps out and measured them. C6, C16 should have been 0.68uF and were in the order of a few nF C14, 26, 27,28 should have been 0.1uF and were 0,.6nF, 2nF, 10nF and 38nF respectively. All other film and electrolytic capacitors were within tolerance. I replaced all the faulty caps thinking that I had found the display problem because you had told me in the past that C6 and C16 relate to the front panel and the cooling issues and fan issues but NONE had been cured :- I checked the continuity to the front panel of all connectiions and they're fine. Also checked the 2 electrolytics on the front board. So I am at a bit of a loss. I have checked the zener diodes in situ and all have about 6v forward voltage drop I cannot find a replacement board due to different connectors on my unit - so unless I can fix we will have to fork out for a new FF :-
See all Toshiba 57h83 57-inch Hdtv-ready Theaterwide Questions
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
