Google Nexus S (16 GB) Smartphone Logo
Anonymous Posted on May 19, 2012
My nexus lost all sounds, only vibrate works?
I left my phone unattented for a while, in reach of kids. Upon return the phone stayed mute. I tried the usual settings but can't get the phone to produce any sound - no ringer - no advices etc What can be the cause and how can I fix this?
  • Anonymous May 21, 2012
    Living in a remote place, we don't have pros around here. Any further suggestions?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on May 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
0
Helped
1097
Points
48
The speaker probably popped see a pro!
tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
Unable to unmute Samsung Galaxy Note 2
-Have you try this.
-Swipe to open.
-Press bottom on the left. It'll pop all the audios function.
-Just use finger tip to touch and slid to the right for maximum. To the left to minimum. It's very sample.
Good luck
Mai Lor
1helpful
2answers
How to remove a password from google nexus 7
I believe the only way to reset your password would be a hard reset. This will also remove all of data and return the device back to the original factory settings.
Reset your Nexus device to factory settings
3helpful
2answers
My Iphone only vibrate it does not ring, How do I fix it ?
Have you checked the mute switch on the top left side of the phone?
If you see an orange dot. Flip the switch up and your ringer will be activated.
Then you can toggle the volume from there.
I hope that helps.
2answers
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
1helpful
Google Nexus One Incoming call Problem
Activate haptic feedback so you can feel the vibration. In the home screen press the button at the left of the home button and select Settings->Sound At the bottom of the Sound settings menu select "Haptic feedback".
1helpful
Turn mute off
Hi
It would be easier to solve this problem if you have shown the model of the cell phone you have.
However the problem is really simple.
All you have to do is to go to Tools and search for sound options or "Silent mode" another option is that you can try pressing one of the buttons (up, down, left, right) on some phones by pressing one of these buttuns you can get the options for your mobile phone, such as Viabration Mode, Flight Mode, Silent Mode or lound Mode.
Another thing that you can search for is "Profiles" this is the option that lets you to shoose any profile for your phone (it can be changed at any time) Every singe phone have different Profiles, some have alot and some have less, here are some of them for LG phones - general = Normal (loud)
- Silent = Mute (no sound)
- Vibrate = Vibrates instead of sound
- Headset = Work only when you plug
in your headphones.
Try to find any of these options...
If you still have any problems with it just ask any of your friends who has a cell phone, then they will show you how to solve it, because it is really simple.
Thank You
Aug 16, 2009 • Cell Phones
2answers
Cell Phone
There are two button on the left side that are for changing the volume. Up will go from mute to vibrate and then to the top volume and then down will go the other way.
My LG Chocolate phone is in mute and I cannot get it out of it. Cannot hear any sound out of earpiece...can only use if it is in speaker phone mode...have I changed the setting somehow....is there a way to...
Not sure if this will help you, but when you slide the phone open, do you see 4 red lit-up indicators surrounding your center data wheel? On mine there are:
Red line - top left
Red line - top right
SPK - bottom left
CLR - bottom right
(Note that the indicators stay lit for about 20 seconds)
The indicator at the top left is the MUTE On/Off switch (you will see "MUTE" in the main display, just above the top left indicator). Although there is no real 'switch' there, you just push on that red indicator. It should vibrate when you turn MUTE on or off.
If the indicators go dark, the switch stops working. In that case, you have to slide the LOCK switch (this is a real switch, on the right side of the phone...it's the middle thing - above the MUSIC switch and below the micro SD opening). Just slide downwards and let go...the indicators should light back up, and you can use the MUTE switch then.
Hope this helps.
And BTW, the reason I am answering this question is because despite all I've just explained, my Chocolate MUTE swith, and all those indicator switches, have recently become intermittent. Which means when I am on an important call, after I switch to MUTE I find I can't get it out of MUTE. So if you try the above and it doesn't work, maybe your phone has a problem like mine....
Jul 07, 2008 • Cell Phones
Top Google Cell Phones Experts
ADMIN Eric
ADMIN Eric
nexrad_chris
NOEL
NOEL
Are you a Google Cell Phone Expert? Answer questions, earn points and help others
