It will show you what channel it is on then the black screen appears. you can see the picture but not in the middle.how do i fix this?
SOURCE: Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Testimonial: "wow its been over a year but what john said was exactly the problem. 20 seconds of figuring out where the closed caption settings were in the menu and problem solved."
SOURCE: My TV has a black square in the middle of the
Your screen is showing a black picture because the closed caption function has been activated. When this closed caption mode is turned on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
Thanks for using FixYa. A rating is appreciated if the solution has worked for you.
SOURCE: A Black square keeps appearing on screen, and wont leave
Hi big john
To answer your question;
What you have is closed caption(CC) in text mode.
To remove it ;
On the original remote there is a button labeled CC
Hit that button until you see closed caption OFF
Hope this help Cheers
