Pump worked fine til I turned it off. When I turned it back on motors humming wont go back on
BLOW OUT THE BACK OF THE MOTOR WITH COMPRESSED AIR. THERE IS TRASH IN THE START SWITCH , AND IF YOUR LUCKY IT WILL FIRE BACK UP. IF YOUR IN THE LONGWOOD FL AREA I DO THIS FOR FREE FOR MY ABOVE GROUND POOL CUSTOMERS
OTHER SHOPS MAY DO IT ALSO, JUST CALL AND ASK
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL 32750. PLESE VOTE YES OR NO IF I WAS OF HELP
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
SOURCE: pool pump noisy
maybe plugged or restricted with something. try cleaning it and see if that will help.
SOURCE: My Mustang pool motor by Waterway musts-120 is
Check your loacl yellow pages for an electric motor repair shop. They may find it is fixable but could at least tell you if it is salvagable or not. Some even carry replacement motors at costs lower than the pool stores.
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: We have a proline above
at home depot the sell a pen that beeps at the sight of voltage (sensor) 12$ good house hold tool to have.. check the cord running to pump see if the pen beeps when held against cord if its a 110 set up the pen beeps and youve the 110 V needed to run the pump if 220 V a bit different .. if left powered But not running in a few min, touch motor housing the metal part of this unit. is it hot as a grill (internal winding problem) or still cool .. Motors are a wear item like tires on ones car.. motors are inexp like 110$ for a 1 hp unit
