How to i enter bios setup in toshiba 5205-s705
Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS.
With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message.
Hope this info helps.
SOURCE: toshiba bios setup
When you just switch on the computer look out for the first screen(before windows even starts up).and try to quickly read usually it will tell you what button to press.depending on the make its usually f12 or del but first check what your model says.
SOURCE: what is the key to enter bios setup in a Toshiba
you can enter system setup in a toshiba system by pressing the esc key or the F1 key on the startup screen.
SOURCE: can't enter the bios setup on the toshiba terca
Please start from dead cold start. Then press the power button and bang on the F2 button like your life depended on it. The BIOS will appear.
Kind Regards,
The Selkie
SOURCE: forget password bios toshiba satlite
To reset the BIOS read the information from this link.
In case of your Toshiba Satellite laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
SOURCE: how to enter bios setup toshiba portege m500
Usually one of the following keys right when boot screen is viewed will get you into bios on most computers.
Esc, F2, F10, Del, or F12 which should be the case with the Portege.
