Canon pixma mp560 all in one
Get easy and instant technical support for Canon printer from our technical expert\'s team. Just you need to call our toll free 1-888-840-8298 Canon Printer Tech Support Number and get resolve your every issues within few moments. For more details you can visit our website here: https://www.supporthelpline.us/canon-printer-support-phone-number
Call Canon Printer Support Number 1800-243-0019 for Canon Inkjet, Pixma and Laser Printer Drivers. Contact Canon Business Support Number for your Business Printer.
SOURCE: Canon Pixma Mp150 keeps having E2 flash
Clear the EEPROM:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
My E2 problem turned out to be a few rails of staples and an earring back stuck in the paper feeder at the back. Removed the staples but the earring back is still in there somewhere....lol. Printer works fine after dislodging all kinds of stuff.... :)
SOURCE: My Canon MP560 is installed on my desktop, and
it means there is no connection between your computer and to your networked pc, chances are either it is really off, or if it is on, if it is ON the communication between your printer and the router is missing at this time, you may need to do the ff
1- reset your printer
2- go to wireless setting on your printer and try to search your own network if your printer found your network, simply (enter the password)
3- if this things didnt help you, try reinstalling the driver once again.
sometimes it does happen, but ensure that your printer isnt place so far away from the access point or from your home router, or there is not much interference, that might be blocking the signal
pls try
SOURCE: doesnt recognise refilled catridge of canon pixma mp145
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
(at this step, i press and hold the reset button twice, each time i
press and hold is about 5 seconds. then i'm able to continue to the
next step)
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff
(if this page doesn't print by itself, press the "color" button once
and the test page will print). Don't worry much about the printed
material. I got some stripped lines and some numbers. I believe that my
colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
(at this step, i have to wait for about two minutes or more then the printer automatically start print the document mentioned.)
8 ) Open the printer cover cover (not the scanner cover) and remove the
cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
11) close the printer cover. Wait for 2 mins. (for my printer, i didnt
wait for two minutes, the light immediately disappeared) The amber
light beside the black ink and color ink will have disappeared.
Also if you take printouts now you will no longer get the ink low warning.If you check the ink status
it will show that the cartridge is full !!! The ink level has been reset successfully."
PS: I did not solve this myself just copy and paste from other source but I tried it and it works.
Do you want it to say "online"?
Solution 1: Restart Printer Spooler service
1) Enter service in the search box from Start menu. Then Click Services (Desktop app) from the result.
2) Right-click on Print Spooler. Then click Restart. Note: If Restart option grayed out, click Start instead.
3) Right-click on Print Spooler again and this time choose Properties. Then set its Startup type to be Automatic. Click OK to save your settings.
4) Restart your PC and try to print your file to see if your printer works.
Solution 2: Disable Use Printer Offline feature of your Canon printer
1) Enter control panel in the search box from Start. Then click Control Panel (Desktop app) from the result.
2) Click Hardware and Sound > Devices and Printers.
3) Find and right-click on your Canon printer under Printers catalog. Then choose See what’s printing.
4) Click Printer to see if Use Printer Offline is unchecked. If it’s checked on with ? mark, click it to uncheck.
5) Click Printer again and this time click Cancel All Documents.
6) Print your file to see if your Canon printer works.
I hope these steps will be helpful!
Mark Wilson
