The machine is making all the right noises but not enough steam is coming out of the steaming arm to froth the milk but seems to be leaking out of the middle part??
SOURCE: steam and froth malfunction
The milk can not be room temperature. It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
SOURCE: Lack of pressure from the steam wand used for frothing the milk.
Hello Juneyjune,
These coffee systems have a series of small rubber 'O' rings that tend to crack from condensation over time causing your low pressure problem.
The 'O' rings are connected to a heater that looks like a horse shoe mounted in back of the grinding unit.
I would recommend contacting Miele technical services. They can have a technician come out to replace the 'O' rings or you can order them from the technical services rep if you know someone that can replace them for you. Just be careful. These machines operate off of 220 volts and that is no fun to get shocked by. I have been many times with this machine
Good luck!!!
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
