MF4410 ERROR CODE E-202-0002
NEED HELP
Posted by ALI BARANI on
bathelomew okezie o
    New Friend:
How can i remove this error E202 0002 on mf 4410
Posted on Nov 05, 2013
vikas verma
  • 504 Answers
Try following following link
http://www.officeland.ws/Canon%20Diagnostic%20Code%20Chart.pdf
and see what problem u have with your error code
Posted on May 19, 2012
Francis Oscar Kollie
1) open the scanner
2)rearrange the two cables that are connected from the scanner to the main board.
Posted on Nov 22, 2019
I have a printer Canon MF4400, when i try to scan the machine gives an error E301-0001. Please help me to solve this problem
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=MF4410&code=E301-0001
Canon MF4410 Error Codes
Quoting:
Code
E301-0001
Description
Insufficient light intensity in shading
Remedy
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
Jul 19, 2018 | Canon Office Equipment & Supplies
I have a canon printer i-sensys MF4410 with error code E301-0001, the problem is that it can not scan and photocopy what can i do to correct this problem?
Code E301-0001
Description
Remedy
Feb 18, 2017 | Canon I-Sensys Mf4410 All-In-One Laser...
What dose code 0002 means in canon mf4410
Hi the only error codei i could find for this model MF4410 printer .,is E202-0002 fault description ::: contact sensor HP error,Failure in return remedy. Check connection of flat cable between main control board (J5) and contact sensor . (2) replace flat cable between (J5) and contact sensor (3) replace the contact sensor (4) replace the main controller board.:::: good luck
May 02, 2016 | Canon Office Equipment & Supplies
Error problem
http://forum.testcopy.net/threads/how-to-fix-errors-based-on-error-code-table-of-canon-lbp-3100-3108-3010-3150.693/
Sep 29, 2014 | Canon I-Sensys Mf4410 All-In-One Laser...
E000-0000
the error E000 is a fuser error, the area of the machine that heats and presses the toner into the paper. It will need professional service.
Apr 03, 2014 | Canon I-Sensys Mf4410 All-In-One Laser...
Canon mf4410 error e100-0001
Make this steps and fix it. God bless you
In order to reset a Cannon copier error code you will need to press the additional functions button on the copier. You will now need to press the 2 and 8 keys together at the same time and release them fast. Now you need to press the additional function button again and then press the copier button.
Nov 13, 2013 | Canon PIXMA MP780 All-In-One InkJet...
What should i do with error e100-0001 on mf4410. i changed fuser film and when i closed the all the panels the machine falshed this error code e100-0001.
Nov 13, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
202 error code mf4410
A piece of paper is stuck in the fuse unit or one of the two exit sensors of the fuser is not in the "up" position.
May 06, 2013 | Lexmark T630 Laser Printer
I sensys mf4410 canon printer display e202-0002
open the scan and make sure that marked ruler like thing where the scana light rest is tightly fixed. that's it ,the error won't appear anymore
Apr 21, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
1,596 people viewed this question
Marvin
Marvin
