SOURCE: Sony Cybershot camera won't turn on
i think dere is sm problem i ur camera battery .....
replace it frm d shop where u hv purchased ur camera n see it works or not....
if dere is still havin problem show it to ur dealer....n tell him d fault...
SOURCE: water damage
There are micro fuse on main PCB of camera first check it. If problem is still not solve than do let me know regards
SOURCE: flash is not coming and error code is E:91:01
Hi!
E:91 is flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center or if they ask too much, feel free to contact me at [email protected]
I work in Sony service center.
Tom
SOURCE: sony Cybershot DSC-W150-turn power on, lens zooms
Hi!
It's probably stuck focus. Contact your local Sony service center, but
if they ask too much, you can contact me at [email protected]
and I will give you a good price.
Tom
SOURCE: SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
