Question about Acer AL1913 19" LCD Monitor
Power light on my acer al1913 monitor flashes green and orange
5 Related Answers
Anonymous
  • 89 Answers
SOURCE: Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Posted on Apr 29, 2008
ebackhus
Erich Backhus
  • 31 Answers
SOURCE: Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Posted on Jan 08, 2009
graemevm
Graeme van Malsen
  • 519 Answers
SOURCE: my acer monitor's power light is blinking green
This could indicate that there is a problem with your display card and not your monitor. Try plugging you monitor into another pc and check for the same problem.
Best wishes,
Graemevm
Posted on Jun 06, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Acer, AL2016W
Open up the set and look for bad caps, see example of a couple years old monitors that failed.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 08, 2010
Anonymous
  • 585 Answers
SOURCE: My Acer Al1715 monitor does not display a picture
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Posted on Feb 02, 2010
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
My Acer X193W power light is orange and it flashes on and off. Pushing the power button has no effect. Only by unplugging it does it go off. Once it's plugged back in, it continues flashing.
the problem is not in to your Monitor the problem is in your PC
  1. press your keyboard nun lock if working and if the light of the keyboard is Green.
  2. remove the memory of your pc and clean it
  3. also check your video card
remove your LCD monitor from the pc and check if you can press the menu of your LCD monitor if that working means your pc is the one have a problems
Not getting any image on my Acer 1913 monitor. It is powered up, I have tried another pin cable and attempted the reset on the front panel. Help!
If the screen flashes on for a second hen turs black, the problem will be more likely in the power supply with bad caps, or inverter circuits are bad, and worst case will be bad lamps. You need to look inside first and tell us what you see, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
It wont turn on
Did you move it recently? If you did, you might want to make sure that the plug is all the way in on the back of the monitor, not just having it plugged in to a outlet.
Acer AL1913 19" LCD Monitor Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
