Washing Machines Logo
Brent Posted on May 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Fisher & Paykel MW512 washing machine which is constantly beeping when it is turned on. The fault error code appears to be 70 for example 01000110 = 64 + 4 + 2 = 70. Is this even a valid code? No one appears to be able to help me!!!
Richard Roth
Level 3:
Top Expert:
  • Fisher Master 9,472 Answers
  • Posted on May 19, 2012
Richard Roth
Fisher Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626597
Points
28464
Here are the error codes for your unit.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 03, 2009
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Anonymous
  • 92 Answers
  • Posted on Feb 22, 2008
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Anonymous
  • Posted on Sep 30, 2009
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Anonymous
  • 71 Answers
  • Posted on Jan 06, 2010
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
Anonymous
  • 41 Answers
  • Posted on Jan 31, 2010
SOURCE: MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Fisher & Paykel GWL11 top loader. Fault code 136. How to fix the problem, the washer won't spin or drain.
Question edited for clarity, turn question around, add CAPS.
It is a motor stall. You need a technician.
Washing Machine - Top Loader Fault Code Numbers
Fisher & Paykel https://support.fisherpaykel.com > article > Washing-M... Sep 30, 2023 - 136, Motor Error - You will need a Service Technician to assist with this - Click Here to ... © Fisher & Paykel Appliances Ltd 2023. Loading.
Questions & Answers for: fisher paykel fault code 136
Fixya https://www.fixya.com > ... > fisher paykel fault code 136 Now Error code 136 means you have a motor stall ... Question about GWL11 Top Load Washer. 1 Answer · What is fault code 136 on fisher & paykel ...
I have a fisher paykel GWL11 that will fill and drain but
JustAnswer https://www.justanswer.com > Appliance Repair May 25, 2017 - If you had a 130 and a 136, the sensor is not likely the issue. Will the tub turn manually? How about lift up and down? Ask Your Own Appliance ...
1 answer · Top answer: Oh, that plastic nut will come off. See the link below. CLICK HERE
https://www.google.com/search?q=Fisher+%26+Paykel+GWL11+top+loader.+Fault+code+136
Fisher and Paykel MW512. How old is my washing machine with serial number: EEN570469?
Question edited for clarity. Please always include full make and model. Question moved to Fisher and Paykel category.
Whereas many companies have a serial number look up, or a code in the serial number, Fiaher and Paykel don't. you would have ot contact them direct.
https://www.google.com/search?q=fisher+and+paykel+mw512+serial+number+lookup
2answers
MW512 stopped during wash cycle full with 3rd 4th & 7th light on. wouldn't restart or reset by power till overnight off. started new wash cycle with same result. Pump spins freely so not blocked!
Check your lid switch. Take a PLASTIC Knife while lid is open and settings are on wash cycle...Stick it in the lid hole then see if washer turns on ..It might be cracked..That wound be the reason some time it works... Sometimes it don't...
Fisher and Paykel MW512. Error Code can't be determined. Light 8 flashes as does lid lock light
exactly which lights are flashing?
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Fisher & Paykal MW512 turns on multiple beeps then turns off
This kind of problem is usually related to a faulty display module, or faulty motor control module (Computer isnide of control panel compartment)
Without spares to change and test with, you wont be able to diagnose 100%
Usually when there is a problem, a series of lights go solid on the control panel and the machine beeps to alert you to a problem and this is a fault code, but if nothing is showing at all, then I have to lean towards the display module underneath the touchpad. Especially considering it wont illuminate.
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
How to remove pump MW512 Fisher and Paykel Washer
Disconnect from power & Bail out all the water you can before removing pump.
3helpful
2answers
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
