The alarm is the fault refer to your alarm manual to disable it, if you don't know about this unit it is best to seek help from someone qualified and available to look at it for you, it seems as if your alarm is set, most alarms have a starter disable function and the alarm going off is an indication that it is set.
SOURCE: I need to take my door panel off my 97 honda
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: need to replace radiator in 1997 honda accord se. what are the steps?
First drain radiator by opening drain valve,"located on bottom corner usualy the right,but not always." If you open the overflow or remove cap this will happen much faster.For safety sake disconnect ground wire from battery,the radiator is locked down by top cover that attaches to body with generaly 4 bolts, upper and lower hoses have to be disconnected and if it is automatic the transmission cooling lines are connected in stacked fashion,"one above the other."The cooling fan has to be unplugged and it should be removable at this point,"when unplugging fan be carefull with connector so it doesn't break.reverse steps to replace making sure the bolts go in the right place and it all fits properly.the thermostat,"located behind the kneck of upper hose," should be replaced after connecting lower hose because in order to fill the block up and prevent damaging thermostat the block shoud be filled with coolant before attaching upper hose.
SOURCE: power window on a 97 honda accord wont go up
possibly your power window regulator is out. basically check the fuses first to make sure you have not blown that, if it is good, then you can order a new window regulator from the dealer or online @ autopartswarehouse.com. to replace the window regulator you will need to will need to remove the door panel, start with the screws on the handle and the arm rest, covered with a plastic cap. the door panel which can be pryed from the bottom with a flat blade screw driver or flat pry bar, it will make a snapping sound. three bolts on the regulator 4 bolts on the window tracks and 2 bolts securing the window, re assemble as you have taken apart, Good Luck!!
SOURCE: 1997 Honda Accord Diagram for 97 honda accord fuse boxes
I NEED A DIAGRAM LAYOUT OF MY 97 HONDA ACCORD FUSE PANNEL THATS UNDER THE DASHBORD DRIVER SIDE
