Question about Sunbeam Hot Shot Hot Water Dispenser 3211-2 Electric Kettle
The water does not cool
I have a dispenser that has three water knobs, hot, cold and room temperature. It also has a small ice box on the bottom. The water does not get cold and the ice box doesn't get cool.
Posted by Kenneth Oglesby on
Fal Mueller
  • 438 Answers
The problem is in the compressor cooling unit, if you have no knowledge of electrical this is beyond your ability to service, it is of refrigerator technology, if so contact me and i will try to help you.
Posted on May 19, 2012
I have a Welbilt 1100-2 refrigerator that isn't cooling as well as before andd not freezing at all. there is no fan and the coils are cleean, any suggesstions? Thanks, Ed
First, I'm Not a Welbilt tech.
* these "No fan" system (in the cold side) rely on the colder cooling coils to be colder than the bottom section. The box seals must be good otherwise warm air disrupts the process of cold air sinking to bottom and getting the whole box cold enough to keep the top section frozen.
* Check the back and bottom of ice box for blockage and dust build up.
* Check the bottom for a drip tray and check if it's full of water. water is okay as it means your defrost cycle is still working.
* Check the sides of box for cold / sweating. It is cool or maybe warm but not ice cold. Larger boxes will have warming areas near the door seal to prevent sweating. Warm but not hot.
* Was this unit moved around (like from another room) and plugged in right away? This things have oil in in them that has to settle after being moved. wait at least 1 hour prior to power up.
* Coils clean, I'm guessing you mean the Ice tray section. It should have a layer of frost on it after 15 mins of power. * Check thermostat. Rotate it all the way in both directions. you should hear a click sound at some point. Do this several times to confirm the click then set it to the middle.
* If any of the above items have problem then you will need service. (though at this price level it will cost more than a new unit.)
* Final, These small student fridges are very simple with a bare minimum of repairable parts. There are YouTube vids that may help but most refer to a unit that won't power up at all. But be sure you chack your warranty as they will probably give you a new unit if it's still on warranty.
.Aloha, ukeboy57
Mar 21, 2018 | Refrigerators
Why doesn't the unit cool when the coil temperature is at 40 degrees F.
You asked why your dehumidifier does not cool; it is not the purpose of a dehumidifier to cool the air going through it. It works like an air conditioner except the hot and cold air are not separated out. The cold [evaporator] coil is the first coil in the air stream where humidity [water] from the air collects just like it does on the outside of a glass of ice water. The air then goes through the hot [condenser] coil where it cools the hot refrigerant and reheats the air before being returned to the room.
If you have the patience to follow along the video, it explains the cycle.
Jan 09, 2015 | Dehumidifiers
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
I have a brand new French door electrolux refrigerator. It was just delivered today. The water dispenser doesn't give cold water - just room temperature. It's only been plugged in for 8 hrs but I...
We have had two different Electrolux French door refrigerators, over the past 2 years and the water never becomes cold. We were told this is because the the storage tank in this particular refrigerator is so small. You just have to drink your water with ice. Unfortunately, we have had recurrent problems with the ice maker as well! Sorry - but these refrigerators are very problematic and I would not recommend them to anyone!!!!!!
Sep 12, 2010 | Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Ice smells and tastes baaaad, water smells and tastes baad!!!! I changed the line and it still stinks...please help...
Check all of this;
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
To remove the breaker strips it is important to bring them up to room temperature first. If they are too cold they will be brittle and may crack. To warm the strips you can open the freezer and allow it to come up to room temperature (wait 2 to 4 hours) or you can soak a towel in warm water and hold it against the strips to warm them.
Good luck:
Don't forget to rate;
Jul 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Build up of ice on bottom of freez
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
May 24, 2009 | GE GSF25XGRWW 36" 25.4 Cu. Ft....
GE monogram side by side no ice water dispensed not cold
To actuate the ice maker pull the arm down and it is in the on position.
The water is actually cooled in the refrigerator section. However it is not designed for a continuous flow. It takes time for the heat to be removed between each water draw.
If your refrigerator temperature is not cold enough it will affect the water temperature also. Check the refrigerator compartment temperature with a thermometer.
May 16, 2008 | GE PSS26MGS Side by Side Refrigerator
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
Kitchen Appliances - Others Logo
161 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Irene Tulloch
Thomas Perkins
Thomas Perkins
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
