Question about HP Compaq ProLiant DL380 G2 Server
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
The server has windows 2003 server r2 and I set the standard boot order for CDROM first but it goes to the 5i controller which is the D drive with Raid 1
Posted by mwillis41 on
  • ooc1234 May 27, 2012
    I've got the same problem, did u figure out any solution ?
Chris D
    Scholar:
  • 50 Answers
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
Posted on Apr 18, 2017
Venkatesh Kulkarni
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 181 Answers
Restore bios to defaults
Posted on Oct 25, 2013
4 Related Answers
SOURCE: Compaq ProLiant ML370 G3
How big if your environment? How many users? Do you have remote access needs? If your environment is under 75 users then you might want to consider moving to Windows Small Business Server. It's a great little package that includes Exchange with it. You can also get the premium edition which includes Sharepoint.
Don't forget licensing needs during this whole process too. You want to make sure you are covered properly with software licenses from Microsoft when making the migration.
The hardware specs seem adequate but it will depend on the amount of users in your environment and workload for it.
I've included three links to different options for migration:
This link is pretty good to explain using the Microsoft tool.
http://www.petri.co.il/active_directory_migration_tool_usage_w2k_windows_2003.htm
This link provides info on the swing migration which is a bit more popular in the small business arena. Works pretty good. I've done it a few times.
http://www.sbsmigration.com/pages/14/
This link is for Acronis products that allow for easy ghosting or copying of data from one server to another. The good thing about this tool is that your SIDs are kept the same. So I don't know if its a big deal (depends on your environment size) but it can be a pain to rejoin workstations to a domain if new servers are added without successfully moving necessary settings. I've used this tool a few times. It's quick and easy.
http://www.acronis.com/enterprise/products/ATISWin/
I look forward to hearing more from you. Please update me on the questions I asked and if I can help further I will be glad too. Don't forget to rate the solutions once we're done! Thanks.
Posted on Mar 31, 2009
micromaster
micromaster
  • 3614 Answers
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Posted on Jul 25, 2008
Anonymous
  • 339 Answers
SOURCE: I have HP proliant DL160 server. How i will make RAID two HD?
Try going into the RBSU(Rom based setup utility) and configuring SATA RAID in the advanced section.
This doesn't work for all versions - if it doesn't help, please be more specific about your configuration, i.e. what "G" level is the server? Hot plug or non hot plug drive? etc.
Posted on Jul 12, 2009
Anonymous
  • 62 Answers
SOURCE: Hi I am having HP Proliant
Remove the BIOS battery and BIOS jumper and place it again. You won't get the error message again at the startup
Posted on Sep 27, 2010
Server won't boot and nothing to even show on the screen i need help urgently.
Are there lights on the front of it? If so, try to re-seat the memory as the first step; servers overheat and are subject to "chip creep". If you don't have any lights, it could be the power supply or system board.
Aug 23, 2013 | HP Compaq ProLiant DL380 G2 Server
Hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
May 07, 2012 | HP Compaq ProLiant DL380 G4 Server
How do i boot a compaq proliant dl380 with a usb drive set up for booting?
Make sure you have turned on the USB Boot in the BIOS of the os. Once this is done, select the order you would like for the server to locate boot files. (Hard Drive, USB, CD/DVD, etc.) Once complete, insert the USB and reboot the server.
Good Luck
C2S
Jun 30, 2010 | HP Compaq ProLiant DL380 G2 Server
I have tried x2 chassis and working memory but cannot get the full 12gb installed and runniing with Win 2008R2. it only takes x4 2GB sticks. Have tested all sticks in other machines and in same one...
Please see the below table to find you are on the right track.
Windows Server 2008 R2 Datacenter 2 TB
Windows Server 2008 R2 Enterprise 2 TB
Windows Server 2008 R2 for Itanium-Based Systems 2 TB
Windows Server 2008 R2 Foundation 8 GB
Windows Server 2008 R2 Standard 32 GB
Windows HPC Server 2008 R2 128 GB
Windows Web Server 2008 R2 32 GB
Feb 17, 2010 | HP Compaq ProLiant DL380 G4 Server
I am using HP DL380 G4 SERVER,cd rom drive is not working , thats why i connected external usb cd rom drive ,and i tried to bood 2003 server os , but failed, please help me................... if any...
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
Oct 21, 2009 | HP Compaq ProLiant DL380 G4 Server
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
Boot problem with a ProLiant DL 380 server,
To enter the BIOS of a ProLiant DL380 you have to press "F9"
Jan 23, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G2 Server Logo
679 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
