HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
Troy South Posted on Nov 10, 2017
How to check ink levels 4180
My HP 4180 is missing the bottom half on the occasional line. (not all of them) It is using a genuine HP cartridge. On my previous HP printer, I used to be able to clean the jets but I don't know how to do so on this model. I don't think the ink is running because the cartridge is not that old,out but how do I check
  • Troy South May 18, 2012
    That should have read "I din't think my ink is running OUT"
5 Related Answers
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Aug 25, 2008
SOURCE: HP Photosmart D7160 insists ink cartridge is empty; won't print
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00414417&dlc=en&product=1156652
Anonymous
  • Posted on Oct 13, 2008
SOURCE: Problem printing with HP Business inkjet 1200 1-800-532-4187 IS SPAM
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
nalin_elliot
Nalin DSouza
  • 224 Answers
  • Posted on Jun 23, 2009
SOURCE: can't find tool box to check ink level - HP 6310 using Vista 2007
doesnt matter most printers have a feature of their own to check ink levels.
press the setup button on the printer and scroll down(with the arrow buttons) till you get tools press ok and now scroll through until you get ink level and select it by pressing the ok button,walla you should have your ink levels in front of you.
Now about the hp solution centre/hp director icon on your desktop (if you have installed the software).
Click on settings and click on printer toolbox and now check your estimated ink levels it will show the ink levels of the printer cartridges.
Anonymous
  • 144 Answers
  • Posted on Aug 03, 2009
SOURCE: Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
Anonymous
  • 42 Answers
  • Posted on Dec 04, 2009
SOURCE: HOW DO I CHECK INK LEVELS ON HP J6480 ALL IN ONE
Click on the "Start" menu button which is located on bottom left hand corner of your screen. Click on the "Settings" bar and notice that a list of functions pop up to the left of the settings button. Click on the control panel icon.
Look for the printer/fax icon in the control panel window. Double click on the printer icon.
Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
Click on "Service this device." You will find the button on the Services menu that you just activated.
Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Deskjet F2100 Cannot get estimated ink cartridge levels to show remaining ink levels. Following instructions from HP solution centre but function does not appear to work. Genuine Hp cartridges hp21 &...
Hello, make sure the golden contacts from your cartridges are clean. If you say your cartridges are Genuine (OEM) and not for use check the valability date on the cartridge (just above the golden contacts). If your cartridges are clean (I am referring to the contacts), OEM (made by HP) and still in the valability range you can take them to the reseller you both them and ask for a refunt or a replace.
Our printer is a hp 7200 ,refil ink cartridges, and because we didn't use hp ink all printing is shut down, can you help? Thank you ****
Unfortunately there is no work around for this.
All HP printers requires genuine HP ink cartridges,also refills are not allowed.
HP ink cartridges has a mechanism only compatible with HP printers that sends a signal to the machine when a non HP ink cartridge is used. I highly suggest you use a genuine HP ink cartridge, there is also a high chance if that your printhead or printing mechanism might be damaged.
Check for ink leaks right away, also make sure to clean the printhead with lint free cloth and use bottled water only. Make sure not to touch the electrical contacts found on the bottom of the print head.
2helpful
Bottom of line missing
First try and go to page setup under file and set your bottom and top margins to .25. is every bottom half line faded? If so then yes you might need a new ink cartridge.
1helpful
Missing yellow when printing/even after many cleaning attempts!
new ink cartridge is much advisable. but for expriment basis i will tell you to place the ink cartridge in the bowl of water only the head from where the ink comes out in the water for nearly 24 hours.then remove the cartridge and clean it completely.then check. hope this helps............
thanks.
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
3answers
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
1helpful
4answers
Cant remeber the ink cartrige #
Hello, there are two ink cartridges for this printer, 336 Black & 337 Color,the cheapest way to buy these is at costo,Please do not refill your old ink cartridges as the printer will on most ocassions tell you to remove the faulty cartridge, however you may get away with a refill only once. I changed to a Brother MFC it was easier to install,prints faster,it has fax,scan,copy phto capture, you will need to buy use printer lead for this machine as it does not come supplied, the bonus of having the Brother MFC 235C is that the 4 ink cartridges are half the price of one HP Black Cartridge,check out www.999inks.co.uk
Alignment
Remove both the cartridges from the printer and check the expiry dates on both cartridges, if any of the cartridge is expired then change the cartridge and check the result. If the cartridges are not expired then check the ink levels present in the cartridges from the HP Solution Center. If the ink levels are good then clean the copper contacts of the cartridges with a soft cotton cloth and power cycle the printer.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
Now insert the cartridges and align them, after alignment page prints then scan the page.
If it still gives alignment failed message then remove the cartridges and reset the printer and check for the result.
Ink cartridge refills
hi,.
   the thickness of the ink in the genuine hp cartridge is different from the refill ink. it will never match. so thats it. try with a genuine hp cartridge and  check whether the printer works fine. else it might be the problem with the printer.
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
k24674
Grand Canyon Tech
Grand Canyon Tech
