Question about JVC KD-G421 CD Player
Will not play discs - JVC KD-G421 CD Player
Posted by Bernard de Grasse on
Why is it a sony BDP-S1200 not play DVD discs but can play blue ray discs?
Check that you are playing the correct region coded discs for your player. Blu-Ray discs tend to be universal but not DVDs. If you are playing Region2 disc when the player is set for region 1 (American) then they won't play and again Vice Versa.
Feb 19, 2015 | Sony Televison & Video
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Im trying to play Wii Fit Plus, but every time I put the disc in i get this message: "The Game Disc could not be read. Refer to the Wii Operations Manual for details." I've tired cleaning the...
Have you tried inserting other game discs? like 3 types of disc. If your Wii console plays those discs and don't play with the game disc that you wanted to play, then the format of that disc is not recognized by console. Some disc formats are sometimes incompatible with the player console.
Nov 04, 2010 | Nintendo Wii Console
My sony DBP 300 is not playng the Disc . It plays the beginng of the disc but seems to freeze and we are unable to play the blu ray disc movie
Try selecting another disc to play, if the next disc plays, it may be the first disc that will not play, also make sure that it is not a 'burnt' copy, if it is....the copyrights may have prevented it from the format being proper. if second movie does not play, it may be the reader inside is dusty/damaged. Also look at dvd disc to make sure it is not smudged/scratched or dirty. take appropriate cleaning measure if it is smudged or dirty,
Oct 17, 2010 | Sony BDP-S300 Blu-Ray Disc Player
My onkyo DV BD-507 only play dvd disc, and dosent play blu-ray disc
Sep 25, 2010 | Onkyo DV-BD507 Blu-ray Disc Player, Black
How to play region A blu ray discs on region c Blu ray player. i have bought this player in India but would like to play BD discs got for USA, and the player does not plays such disc.
The Player will not play the Blu-ray discs other than Region C.
This is because all the Blu-ray/DVD Players are designed such way that it will play only the discs that are manufactured and sold in the same country where the Player is manufactured.
You can play the discs that are "Region ALL".
However, you may try copying the content of the Region A/B Blu-ray discs to a Computer then create a video Blu-ray disc to check whether you can play them in the BDPS370.
Jul 21, 2010 | Sony BDPS370 BluRay Player
Plays some won't play others firmware is up to
Please check in the manual provided which regions disc your Blue ray disc player can play. Check the same region code at the back cover of the Blue Disc you want to play. If it is same there is no problem in playing but if it is other than the one your player can play, it won't read or play. Try to get Discs which have all regions marked on them
May 01, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
Feb 03, 2010 | Panasonic DVD-S25
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
JVC KD-G421 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
