THE MACHONE HAS A NEW TONER INSTALLED AND KEEP ASKING FOR A NEW TONER
Step 1:- Switch off the machine
Step 2:- Press 0 & 5 simultaneously
Step 3:- Switch on machine.
Step 4:- The display shows test mode.
Step 5:- enter code 200
Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display.
Step 7:- Now switch off & on and check the problem should be
resolved. If problem continues then maybe, changing your
developer may solve the issue.
SOURCE: i have a toshiba e-studio
Use your hand and tap the tube going to the used toner bag. Does it sound full? sometimes the toner will clog the tube and back up. You need to knock it loose so that the waste toner will empty. Also check the waste toner bag switch, it may have gotten knocked out of position when removing it the first time. If so just reposition and / or reshape.
SOURCE: Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
SOURCE: keeps on coming up with install new toner
It was a e studio 350 not a 232 that I was looking at , but that doesnt matter the problem is the same and it ended being the toner sensor in the dev unit, so I replaced it and now its working fine.
SOURCE: toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
