It sounds like it is always ideling not running at full RMP to mow properly. Any ideas??
SOURCE: where are the oil drain plugs for a poulan pro 550
under the deck above the blade. It is probably a square head pipe plug
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
SOURCE: the poulan pro 550 series is what i have and the
i have a poulan pro 550 series and my string broke
SOURCE: how do i clean the air filter for my poulan pro
You can only clean it if it has a replaceable (fabric-type) filter...If it is paper, it is disposable and will have to be replaced if bad.
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
