Video Game Consoles & Games Logo
Question about Video Game Consoles & Games
Cant get output ps3 on hdmi cable
Got brand new ps3 conected it to alba tv with hdmi keeps saying no video available so tried on 2 different sony tvs and worked fine why cant i get it to work on the alba
  • 4 more comments
  • Anonymous May 18, 2012
    Are you able to get a picture on the tv when using the original A/V cable?
    Also, are your controllers syncing properly with the PS3?
    yes i used the other cables with the alba tv and can get the pic fine even done the sofware update controllers are fine
    yes the other cables are fine with the alba tv have done the software update using it that way controllers are fine
    OK JUST BROUGHT THE THING DOWSTARS AND PLUGGED INTO SKY BOX AND GOT SAME RESULT SO IM THINKING ITS THE HDMI SOCKET ON THE TV
    To be honest the best solution at this point would be to contact Sony support, provide them with everything you have already done. Chances are they will offer to replace/repair it. The other options would be to use the original composite A/V cable or component cable.
    dont see why i have to contact sony theres nothing wrong with the system as i plugged it into 2 sony bravia which i have with hdmi and worked fine its the tv which is alba im goung to contact argos as the tv is still under waranty and i should get it fixed or a new alba tv you see its not for me its my sons birthday present and i dont like it not having the quality of picture i get on my ps3 and my tv thanks for all your help anyway
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • Posted on May 18, 2012
    • 1 more comment
      have done both of these and still keeps saying no video available have used the hdmi cable and ps3 with sony bravia worked strait away so i know its not the cable or the ps3
      did both same resuilt
      Just in case it doesn't show above:
    2 Related Answers
    Anonymous
    • 149 Answers
    SOURCE: PS3 wont work with AJAX after using HDMI cable
    ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
    to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
    Posted on Nov 05, 2009
    fkuk
    fkuk
    • 311 Answers
    SOURCE: PS3 HDMI - Sony Bravi KDL-40V2000 Problem
    • Have your ps32_bing.gif in standby mode (red light).
    • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
    • Wait 10-15 seconds. A display will show up, and just answer yes to all!
    try this
    Posted on May 08, 2010
    Connect ps2 to tv
    Most new TV's are coming out with only HDMI inputs. If your TV has only HDMI, and a (cable) in, Then there are 2 ways to connect your PS2. 1) Buy a rca(audio/video) to HDMI converter. These are available on Ebay in several different designs.2) Buy a PS2 cable ready coaxial converter available from Ebay, or your local gamestop store. Remember, the cords for the PS2 and the PS3 are EXACTLY the same.
    2helpful
    Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
    hi
    There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
    or try this
    Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
    ok
    5helpful
    2answers
    try this
    My playstation will not shoe up on my tv..im at the hdmi chanel and its saying no signal??
    hi def tvs may have 4 or 5 inputs for different things.
    hdmi
    cable
    component1
    component 2
    try a different input on the tvs remote.or check where the x box is plugged into.
    3helpful
    Why my hdmi cable keeps saying unsupported signal. check your device output
    use a normal cable to connect to you tv and check the resolution that the hdmi is trying to output. if it wont display with the normal one then you will have to reset the video output system.
    http://www.tipstrs.com/tip/1888/Reset-your-PS3-video-settings
    2helpful
    My ps3 has no output. tried two HDMI cable and the factory RCA cables on two different TV's. Both Tvs say no signal. Console will come on and run like normal though.
    you have to do the video reset
    to do the video reset put the ps3 in standby mode(red light)
    then press and hold the power button till you hear 2 beeps and let go this resets the video
    23helpful
    PS3 No signal to the TV
    To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
    My ps3 only works with hdmi cables?
    Did you try holding down the Power button until you heard 3 beeps? It is not uncommon for the video output to exceed the resolution of different television. This hard reset feature was added to troubleshoot such a problem, factory resetting the video settings.
    6helpful
    Hdmi connection doesnt work on ps3
    By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
    Top Video Game Consoles & Games Experts
    Marvin
    Marvin
    Aron
    Tom Chichester
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
