Question about DeLonghi EC Coffee Makers & Espresso Machines
How do I reset my delonghi ec860
Brand new machine, just took it out of box & the hot water light just keeps blinking.
dukehyung
    New Friend:
My coffee machine is not working,,, the water ligh is blinking green n not doing anything.. anyone can help with this?
Posted on Mar 08, 2013
  • 5 more comments
  • Nass Sep 30, 2013
    Im having the same problem
  • Cathy
    Cathy Dec 26, 2013
    I am having the same issue that only B8 is blinking not the sequential flashing of lights as per the instruction. So, it does not seem doing self testing. Please let me know how to fix it or should I return it immediately? Thank you,
  • Marcus
    Marcus Sep 16, 2014
    I had the same issue. I was able to resolve it by plugging in that small silver plastic tap/valve (I don't know the proper name) and then pressing the hot water button.
  • Kiwie Kwan ()
    Kiwie Kwan () Apr 04, 2015
    Can show picture what is the silver hot water valve?
  • Sara Thompson
    Sara Thompson Feb 29, 2016
    For all those with this problem. Here is a pic. Attached the hot water pipe firmly and cycle through some hot water. Worked for me.
  • Anonymous Apr 12, 2019
    it worked! thanks!
  • Anonymous Apr 18, 2019
    Wow it worked for me too .... Thanks a lot
fschmeck
    New Friend:
  • 6 Answers
Answer posted by Marcus worked for me. Plug in silver hot water valve, and press and hold the hot water button. Light when off and water came. Possibly had air in system?
Posted on Oct 12, 2014
  • 5 more comments
  • paul nankivell
    paul nankivell Feb 13, 2015
    i have the same problem. what is the silver hot water valve and how do you plug it in? thanks
  • Sara Thompson
    This worked for me. The hot water valve is the long silver tube that attaches to the milk intake.
  • Sara Thompson
    Here is the hot water valve
  • Dawid Spangenberg
    Dawid Spangenberg Dec 25, 2016
    Thanks Sara!
  • Dawid Spangenberg
    Thanks Sara!
  • BEHRANG DARYAKAR
    BEHRANG DARYAKAR Mar 25, 2017
    valaaaaaa....good ...tnx a lot now is working ....
  • Michael Arthey
    Michael Arthey Apr 28, 2021
    fschmeck, THANK YOU.
Ahmed Abul Ela
    New Friend:
I have one new but its not steeming only coming hot water inever used its new what can i do ,lighting only like flashing :(
Posted on Nov 18, 2018
Sara Thompson
    New Friend:
For all those with this problem. Attach the hot water pipe firmly and cycle through some hot water. Worked for me.
How do I reset my delonghi ec860 - reset-delonghi-ec860#sln-34561835-mqf4i2wmo3psntgsn5i2c0t3-1-1.jpg
Posted on Feb 29, 2016
3 Related Answers
alex cataldo
  • 70 Answers
SOURCE: water light keeps blinking and won't brew coffee?
it sounds like either the pump is giving out or the flowmeter.
since it is releasing water from teh steam valve, i'd aim more for the flowmeter giving out.
Not sure if saeco sells them to the public. Usually gets sent out for repair. Repair will run ya 100-150 usually.
Posted on May 23, 2008
Anonymous
SOURCE: no water light on new delonghi magnifica
I had the same problem.
As the machine is brand new, try washing the infuser under the hot water tap and then dry it. I then made a 2 cup long coffee and the red no water light stayed off.
Posted on Apr 11, 2009
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: Help! The warning light regarding
motor no good may be pcb needs testing...
Posted on Mar 04, 2011
I have a DeLonghi EC860.M that will not descale.
Descaling
  1. Remove the water filter. Fill the tank with the descaling. ...
  2. Insert the hot water spout (fig. 8).
  3. Place one container under the boiler outlet and one under. ...
  4. Simultaneously press the. ...
  5. Press the. ...
  6. Once the descaling solution is terminated, the light. ...
  7. To eliminate the solution and lime scale residues, rinse the. ...
  8. Press the.
https://www.manualslib.com/manual/594778/Delonghi-Ec860.html?page=14
My DeLonghi EC860 will only light either red or top green water solid no flashing light. I replaced the the control board still same problem. It was working great then it didn't.
3D Silk Eyelashes China 3D Silk Eyelashes Factory Mink Lashes Manufacturer Silk Lashes China 3D Silk Eyelashes Factory Mink Lashes Manufacturer, fast delivery and wholesale price is directly from factory. We accept OEM 3d silk eyelashes, black/clear band lashes is Available. Our 3d silk eyelashes is Super light. Private label for 3d silk eyelashes and custom box bulk order with discount is available.
Red light keeps flashing all the times
Witch red light?
Could be that the red light telling you to descale the unit is flashing.
if so then you have to descale the unit...see manual
Why won't the steam function work on my brand-new out of the box DeLonghi Magnifica Espresso Machine?
The steam heater is probably not working. Check your manual to see if there is a fuse or reset switch for it. If that doesn't work, return the machine to where you got it for an exchange.
My Delonghi EC 850 has a flashing red light (the one that you use to switch on the power.) The manual doesn't indicate what that means? Does anyone know how to fix it.
The Machine needs cleaning, just follow the instructions in the video link here: https://www.youtube.com/watch?v=js8vfk0W4Sc
Note: if you don't have the kit just do it with water only to switch off the red light.
My delonghi ec860 red light keeps blinkin when coffee finishes coming out what does that mean.
Robert is it the light that has two signs underneath, if so then it is time for descaling.
kolbrun
Brand new machine, out of packing. No self test, just green flashing water light. No noise, nothing happens at all when button is pressed and held, pressed and released.
I think I would start by contact the seller and ask why a brand new machine behaves like that.
Then there is always the troubleshooting chapter in the user manual. If yours isn't handy you can always get it here Free User Manuals and Owners Guides ManualsOnline com K
No water light on new delonghi magnifica
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
