SIR/MADAM
If you have print quality problems, clean the drum unit as follows:
1.Turn off the printer power switch. Press the front cover release button and then open the front cover.
2.Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
3.Release the gray lock lever (1) that is on the left side of the printer. Pull the drum unit completely out of the printer using the green handles on the drum unit.
- We recommend that you place the drum unit on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
- Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
- Hold the handles of the drum unit when you carry it. DO NOT hold the sides of the drum unit.
4.Hold the handle of the toner cartridge and pull it out of the drum unit. Repeat this for all the toner cartridges.
5.Turn the drum unit over by holding the handle. Make sure that the four drum unit gears are on the left side and the drum unit gear "1" is located furthest away from you. The numbers can be found on the drum unit gear.
6.See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Put the print sample in front of the drum, and find the exact position of the poor print.
7.Turn the drum unit gear toward you by hand while looking at the surface of the drum (1).
8.When you have found the mark on the drum that matches the print sample, hold the middle of a cotton swab and wipe the surface of the drum gently until the dust or paper powder on the surface comes off.
Caution
DO NOT clean the surface of the photosensitive drum with a sharp object.
9.Turn the drum unit gear toward you by hand to return it to the home position. The home position of each drum can be identified by matching the number on the drum unit gear to the same number on the left side of the drum unit.
10.Make sure that the number on each of the four drum unit gears matches the corresponding number on the side of the drum unit.
11.Using the green handles turn the drum unit back over.
12.Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum unit, and make sure that you fold down the toner cartridge handle (1) once the toner cartridge is in place. Repeat this for all the toner cartridges.
13.Put the drum unit back in the printer as follows.
- Make sure that the gray lock lever (1) is in the up position and put the drum unit in the printer. Push down the gray lock lever (1).
When you put the drum unit in the printer, match the green guides (1) of the drum unit handle to the green arrows (2) on both sides of the machine.
2.Push the drum unit in until it stops.
14.Close the front cover.
If your question was not answered, Please Visit Below URL For Brother Printer Issue:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002200/000056/faq002256_001.html?reg=us&c=us&lang=en&prod=hl4040cn_all
OR
In Case You Still Need Online Assistance For Online On:
Brother Printer Support
1.
4.
5.
7.
8.
9.
10.
12.
13.
14.
