Computers & Internet Logo
Question about Philips Computers & Internet
No control buttons on Philips 234CL (lit but not possible to turn off)
I want to turn Smart Image Scanning off, but the buttons on the foot of the screen seems irresponsive? How to fix this?
Richard Bittner
    New Friend:
Philips 234CL
Go to:
Control Panel
Hardware and Sound
Devices and Printers
Select >> Philips 234CL
Select >> Display Settings
Select >> Advanced Settings
Select >> Graphics and Media Control Panel
Select >> Graphics Properties
Select >> Monitor/TV Settings
Select >> Restore Factory Defaults
Posted on Jul 09, 2013
  • Richard Bittner Jul 09, 2013
    Philips 234CL
    Go to:
    Control Panel
    Hardware and Sound
2 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: philips 223E1 monitor controls locked
http://www.fixya.com/support/r4646147-philips_lcd_monitor_loc_unlock
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 13, 2010
Anonymous
SOURCE: how to fix philips I9IEL smart image on and off
what will i do to stop it?
Posted on Dec 16, 2011
How do i turn off smart image off on my philips 242g5dejb
the last button & press & hold for some seconds it will go off
4helpful
How to disable of smartimage
In Philips 220CW8FB 22 inch LCD Monitor,
go To bottom o your lcd, press first button on your lcd , And hold up approximately 3-4 Seconds. And smart image will turn off .
1helpful
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
3helpful
Smart image on philips lcd on screen
Dont Buy Philips monitor. I have 20 pcs monitor and after one year half of them had malfunction. smartimage with vertical lines back and forth and that all controls are locked that cant be unlock by holding any button. Some had white screen when Resolution exceed 1024X768 (when 1280X768) after a year.
Maybe they program it to malfunction after a year. My CDR king and AOC monitor had no problem 2yrs to present date.
Philips monitor are garbage
Sorry for bad english.
17helpful
2answers
How do I turn off the smart image?
Welcome to Fixya.
Starting from the bottom, press and hold the first button for approximately 5 seconds and the option smart image will be turned OFF.
Thanks for using Fixya.
How do scam a piture unto my computer
  1. Blow the dust from your scanner and printing area with canned air. Clean the scanner bed and the underside of the document lid with a damp, lint-free cloth before scanning.
  2. Get your computer and all-in-one printer turned on and talking to each other. Open the scanning software on your computer if needed. If not, you can use the controls on your printer to run the show.
  3. Lay the picture to be scanned face-down on the glass. Square up the photo using the guides that are usually located along the edges of the scanning bed.
  4. Close the lid.
  5. Go for a higher dpi (dots per inch) count if you plan on displaying the scanned image at larger-than-life size. Otherwise, you can select a lower resolution.
  6. Click the scan button on your computer's scanning software window. Some all-in-one printers need you to press the scan button on the printer itself; check the manual before using.
  7. Get a preview of the scanned image up on your computer monitor. This might happen automatically depending on your software settings; if not, you will have to prompt your computer to display one.
  8. Correct small defects such as red-eye in the image. Save extensive changes for later with dedicated photo-editing software.
  9. Accept the scan and save to your hard drive. Remember to put your picture away
734helpful
11answers
Smartimage problem on screen
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Remote codes for philips universal
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Top Philips Computers & Internet Experts
Marvin
Marvin
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
