How to hook my phone into my alpine cda-9857 cd player threw bluetooth
Bluetooth
Posted by randybart541 on
    Top Expert:
  • Audio Player... Master
  • 76,851 Answers
Download the user manual to your Alpine car audio. It will have all details. To download it, click here.
Posted on May 18, 2012
1helpful
There is a cd stuck in the deck. It wnot eject and won't read. How can I get it out?
the best way to get it out is to take the deck apart if you can see th cd try tweezers or needle nose id bet there is more than one in it i hope this helps
How ican conect my ipod
here's your best start...
jump on eBay and type in your model number: CDA-9857
Lots of the ipod input adapters out there on eBay.
The adapters hook up to the back of the Alpine CDA-9857 deck.
2answers
Hi i turn my alpine on and i have 2 retune the radio stations i store them but when i get back in my car i have 2 start 2 retune any idears
Probably you dont have the constant pos (+) wire hooked up to hot (+) wire and only to a source that is switched. Switched means every time your key is removed from ignition switch the positive current from that source will also power down. There are two positive leads from the unit, 1 always hot and the other needs to be switchable. The constant hot (usually yellow) powers the memory for your settings. Just like your television set, once you pull the cord off the socket everything returns to default setting.
7helpful
Have an alpine 9886 stereo and cannot connect my blue tooth ready phone...
Hello maslynab,
The Alpine CDA-9886 is Bluetooth ready but requires an adapter such as Alpine's KCE-400BT or a generic adapter in order to pair with a phone.
Hope this helps.
2helpful
Hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Alpine CDA-9857 Volume Fluctuations
Please see my solution posted on Mar 13. No other brain waves yet!
Tuning Radio
Users manual is HERE.
The Constant +12 volt wire is the yellow one. Wiring connections begin on page 34.
Best of Luck.
Works fine through 4 chnl. amp on radio until you switch to cd then rear speakers turn off
You have the amp hooked to the "Antenna turn on" which is the blue wire.... you need to hook it to the "REM" output whis is Blue with a white stripe.
Alpine cda 9857
You can download the manual from the link below: http://vault.alpine-usa.com/products/documents/CDA-9857%20OM.PDF Please update the question & let us know if the information given was useful to you - Good Luck!
2answers
Alpine CDA-9857
You need to purchase a 30 (thirty) dollar cable from best buy. Mike
 Grubhead
Grubhead
Marvin
Marvin
