Microwave Ovens Logo
Posted on May 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ge microwave surface and oven light not working as well as turntable
Lights & turntable quite working after suface lights burned out
  • Anonymous Mar 15, 2014
    surface lights & turntable don't work... which fuse is probably blown? how do i get to it?
Anonymous
Level 3:
  • GE Master 6,771 Answers
  • Posted on May 18, 2012
Anonymous
GE Master
Level 3:
Answers
6771
Questions
0
Helped
1777270
Points
21413
The problem is in one or two of the door switches, or the keypad control board is the source of trouble.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 25, 2006
SOURCE: GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 02, 2008
SOURCE: ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Anonymous
  • Posted on Aug 14, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 16, 2008
SOURCE: GE Profile Spacemaker microwave surface lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
David Hanks
  • 178 Answers
  • Posted on Sep 11, 2009
SOURCE: GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
2helpful
2answers
My GE JVM1540 microwave appears to run but it won't heat. The lights and turntable work but it does not heat at all.
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
I have a GE Microwave oven model JVM1790SK01. The surface light switch doesn't work - the lamp stays on all the time; won't dim to night light and won't turn off
There are wires going from the main board to the surface lamp and turntable. They are thin orange, yellow and blue wires. I think the surface lamp is yellow and the turntable wires are orange. You should first try taking the bottom cover off. There are about 8 screws under neath and the bottom cover hinges on the back edge, just let it hang. You can now see the wires. Those wires short to the case where they go through from the main board to the lamps or turntable motor. You now have to move them away form the case. Sometimes they get pinched to the metal cabinet by the lamp socket area. Look for signs of pinched wiring there at the lamp socket or where they go through. Move them away, tape up the bad area.
2helpful
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
1helpful
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
GE XL1800 will not heat
sounds like the twt is bad (the traveling wave tube) that is quite expensive. Unfortunately your solution is probably to buy a new one.
2helpful
GE XL1800 Suface light
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Surface Lights Don't Work
We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
