When i switch on the printer it prints the test sheet
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
SOURCE: My printer keeps printing the test page every time it's switched on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place
the test page on the scanner glass and press the SCAN button
on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
SOURCE: keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
SOURCE: Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
9. Remove the pickup roller.
Figure 9: Pickup roller
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
Figure 17: Reinstalling the pickup roller
SOURCE: colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment
Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size:
Letter
Default Paper Type:
Plain
Manual Feed:
Off
Duplex:
Off
Bind:
Long Edge
Tray 1 Size:
Any size
Tray 1 Type:
Any Type
Tray 2 Size:
Letter
Tray 2 Type:
Heavy 111-130g
Paper Out Handling
Specify Time and Action
Paper Out Time:
0 Seconds
Paper Out Action:
Override
SOURCE: My Hp D2660 printer starts
Check the length of the USB cable . If it is longer than 10' it will cause the problem of stopping half way through a print
