The video graphics went out and I can not see the screen. I replace the video graphic card and I still can not see the screen.
SOURCE: video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
SOURCE: Installing a video card
first, do not disable the display graphics..then you have to install the driver or software of your vidoe card to be able to recognize by your system. then you restart . see if this will work..
allen
SOURCE: Motherboard - disable onboard graphics
1. open your cabinet.
2. remove the battery form the motherboard.
3. wait 15 seconds and then replace the battery again.
4. connect your screen to the pci ex card.
now it should work.
CS
SOURCE: Dell Dimension 5150 doesn-t support radeon X1600XT
your system is ddr 2 not ddr3 and the cards above are ddr3 sorry but you need ddr2 compatible grafics cads thanks
