I WONT TO DELETE ALL, CONTACT FROM MY PHONE 6230I AND CHANGE PHONE TO DEFAUTE SETTING BET THE MESSAGE I RECEIVED IS THAT I SHOULD ENTER PHONE SECURITY CODE AND I DONT KNOW THE SECURITY CODE OF THE PHONE, PLEASE HELP ME OUT.
The best solution for your mobile is to do a master rest. It would restore your phone to default factory settings as you expected. You can get a free master reset code for Nokia 6230i from www.unlock-free.com/nokia-master/nokia-6230i.html just submit your IMEI number here and the free code will be provided to you.
SOURCE: FORGOTTEN MY SECURITY CODE 4 NOKIA 6230!
FORGOTTEN MY SECURITY CODE 4 NOKIA 6230! MY IMEI IS 356952/01/01184880/3
SOURCE: nokia 6230i security code
hi
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
By Mr.GINKO plz do rate this post
SOURCE: I have forgotton the security code of nokia 6230i
press Call key + * + 3 + power button for a couple of seconds. Note
that you have to press the four keys at the same time, otherwise it
won’t work.
IT WILLREMOVE ALL DATA ON YOUR PHONE
if it dont work then try flashing ur phone by NSS or any other software NOTE:IT WILL VOID YOUR WARRANTY
IT WILL REMOVE ALL DATA ON YOUR PHONE
SOURCE: nokia 6230i securitycode
After installing file manager check the folder C:\System\mmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
