SOURCE: Belkin F5D7011 wireless network card
Hi
You can download it from the link below (Free of Charge)
http://www.belkin.com/support/article/?lid=en&pid=F5D7011&aid=5391&scid=221
Good Luck
SOURCE: wirless network card
well i think obviously the network card is damaged and causing the pc to stop when checking the pci slot that the card is in. Return to the supplier as the card should light up orange or green when operating normally, and under warranty if Os has a 12 month warranty period. Assuming you haven't had a power surge, they should replace the card.
SOURCE: belkin network adapter driver problem
this driver is constant problem, the best way to do it is to remove the driver and the adapter. re install the software, then connect the adapter to a different usb port and try again, or, connect the adapter and then when it asks for a driver point it to your cdrom where you have the driver disc and force it to install from there, once installed, open up the belkin manager console and dissable it and allow windows wireless zero configuration to run the adapter it is more stable
SOURCE: Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
SOURCE: i am looking for drivers for Belkin 54g Wireless
you will having a model number that starts like f5d7000 and also will have a version number printed in the card itself...
you can download the driver by selecting the appropriate version below...
click here...
