Frigidaire oven overheating
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
