Question about Juicers
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
My 3 month old Philips Avance 1871 Juicer has just stopped whilst I was juicing lemons. There is nothing stuck and I've completely cleaned it and tried to start again but nothing is happening - what should I do?
Posted by Heidi on
Susie Bacon
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
Posted on Sep 17, 2013
5 Related Answers
pego
SOURCE: Cleaning a Mesh Filter on my Juicer
The stiff brush that came with mine has worked well for me. Have you tried a fingernail brush or maybe some canned air?
Posted on Nov 19, 2007
Anonymous
  • 3 Answers
SOURCE: Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Posted on Mar 06, 2008
Anonymous
SOURCE: Juicer stopped working
Fuse may be blown. Take off bottom, it is soldered to the circuit board. Unsolder and replace (I use a fuse holder) to make it easier
Posted on Jul 12, 2008
Anonymous
  • 3 Answers
SOURCE: Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Posted on Dec 12, 2008
Anonymous
SOURCE: rival juice extractor model 965
Trying to find a Rival Juice Extractor #965 Product Manual, Please help
Posted on Feb 13, 2010
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
A small slice of cabbage got stuck at the bottom of the funnel where the vegetable goes onto the blade. The motor stopped immediately and is now not working. This same mishap happened about a year ago...
A small piece of cabbage should not stop this machine. If it did stop, look for the red reset
button on the bottom of the juicer. I've been using mine for 21 years and occasionally it will
stop when run for an extended period especially if vibration is present. In each case I waited
a few minutes and pushed in the reset button.
Mar 29, 2011 | Acme 6001 Juice Extractor
My #6001 juicer ( old!!) will make a very loud sound even after only 3 carrots.. causing me to stop and clean out pulp.. even may shake more than usual... so am thinking it should need an overhaul??? I...
No overhaul. These juicers do not eject the pulp and are subject to vibration especially if you
install a new blade. I've had one for 21 years and get by using a worn blade which I sharpen
with an electric drill using a small bit.
Mar 03, 2011 | Acme 6001 Juice Extractor
Ican not remove the the basket for cleaning is to hard
You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Feb 16, 2011 | Salton JM411 Juiceman II Elite Juicer
How can I clean the residue from a Krups juice extractor--the white parts have an orangeish crust on them. (carrots)
Try washing the white parts of the juicer with lemon juice. That worked very well for me. There is a faint tint that remains, but not the orange coating.
Feb 10, 2011 | Krups Juice Extractor
Was just juicing carrots and the motor stopped , now when i switch on all i hear is a whir sound but I dont think it is rotating at all what should i do to get it working again?
I am having a similar problem, turned it on to juice carrots, it sounded like it was rotating very slowly then the motor just stopped. Would love a fix, i am addicted to my juicer and would be very sad if it was not good. It is only about 2 months old.
Jul 15, 2009 | Jack Lalanne Power Juicer (Stainless...
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Nov 26, 2008 | Jack Lalanne KN2047 Juicer
Juicers Logo
446 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
